Need Help With Engine Knock
Old May 27, 2011 | 09:56 PM
Houndstooth's Avatar
Houndstooth
Default Need Help With Engine Knock
I have a knock that just surfaced tonight. The oil level is good and it is clean. The nearest I can tell the knock is coming from the bottom end, it seems to be loudest where the balancer meets the block but I can't find anything loose. I'm guessing it's a rod but I'm not sure. It is loudest at idle and goes away when I bring up the rpms, I thought a rod knock would get louder when the rpms went up. Any ideas?
Old May 27, 2011 | 10:00 PM
JMD's Avatar
JMD
How is your oil pressure? (if you have a gauge)
Don't jump to conclusions at least until you check the flex/flywheel and the torque converter/clutch to make sure they are not coming loose or are cracked. Many "engine knocks" originate from here causing many an engine to be pulled needlessly.
Old May 27, 2011 | 11:12 PM
Houndstooth
Well this is embarrassing but I figure I'll post the problem in case somebody makes the same mistake I did (doubtful). It was the crankshaft pulley. One of the bolts came loose causing it to wobble against the balancer but not so much that I could see the wobble. I tightened it up and the knock is gone. I feel stupid but at least it's not a rod!
Old May 27, 2011 | 11:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
Wish I was as lucky as you. This happened to mine and it had less than 50 miles on it.
Old May 28, 2011 | 05:30 AM
Rat fink's Avatar
Rat fink
Don't feel stupid, feel happy and go give that car a good wax job.
Nick Oliver
Oct 17, 2018 04:22 AM
degner122
Sep 16, 2015 07:09 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
