E Fan Shroud Modification
Old Jun 8, 2011 | 06:25 PM
wgc68nyc's Avatar
wgc68nyc
Default E Fan Shroud Modification
Just got my new e fan and shroud that came with my new aluminum radiator. The mounting gear that they sent would be used to mount the fan directly on to the radator and have it inside the shroud.
I have a feeling (and think I read somewhere) that there should be be a bit of a gap between the shroud/fan and the radiator for better pulling effectiveness. Thoughts? It should be easy to drill a few hole and mount the fan on the outside which may help the fan pull some air from the corners.
Here are the pics of the fan inside and outside the shroud (sticker cover is still on the shroud)
https://picasaweb.google.com/W.Casag...eat=directlink
Also should a 140amp alternator be enough for a basic 4 speaker stereo, the e fan, and an aftermarket A/C unit from Old Air?
Old Jun 9, 2011 | 09:33 AM
JMD's Avatar
JMD
I don't think you will need to leave a gap on that install unless the shroud (or fan itself) somehow contacts the radiator fins or tubes.
Old Jun 9, 2011 | 09:36 AM
TexasAxMan's Avatar
TexasAxMan
I think e-fans are meant to be up against the radiator, only belt driven fans need the 1" clearance due to engine movement.
Old Jun 17, 2011 | 10:20 PM
wgc68nyc's Avatar
wgc68nyc
Thanks for the advice. It turns out it would not have fit on the outside. Finished product:
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
2016PP
Sep 23, 2015 09:51 AM
