ELEANOR stripes
Old Jun 13, 2011 | 10:32 AM
67Eleanor's Avatar
67Eleanor
Post ELEANOR stripes
Hello again if anybody knows please help me out with the Eleanor stripes dimensions and sizes , mustang depot gives the dimensions for the side stripes but not the big racing stripes .
What am looking for these stripes : http://www.google.com/imgres?imgurl=...w=1360&bih=673
And these side stripes : http://www.google.com/imgres?imgurl=...w=1360&bih=673
thank you
Old Jun 13, 2011 | 11:45 AM
82firebird's Avatar
82firebird
Typically, for the 2 striped LeMans stripes, guys are just using the LeMans Demensions. However, the First picture you showed is using the Mustangs to Fear hood, which uses a narrower hood scoop than Maier, etc. so you would want to adjust your stripe demensions accordingly or your stripes will look too large for the scoop.
What hood do you have?
Here are the LeMans Stripe demensions.
The licensed sidestripes can be found from Tony Branda, same as were used on the 67 GT500's. You can also look to Aeroform for their reproductions, which is available in a reverse stencil if you want to paint the stripes on.
Old Jun 13, 2011 | 12:27 PM
67Eleanor's Avatar
67Eleanor
i have the low rise Eleanor hood http://www.mustangsunlimited.com/ite...sp?T1=EH68A+01
Old Jun 14, 2011 | 06:58 AM
kalli's Avatar
kalli
i'd lay out those and see what it looks like with your hood/car
https://mustangforums.com/forum/clas...s-stripes.html
Old Jun 14, 2011 | 07:10 AM
67Eleanor's Avatar
67Eleanor
what would you think is best to go exactly by the width dimensions on the pdf or just use the same width all around ?
Old Jun 14, 2011 | 09:15 AM
kalli's Avatar
kalli
i'd lay them out with a thin piece of masking and fill them in with paper or similar so you can see what it's going to look like
I'd use the original one and from there just make the striping thinner or thicker if it needs be.
I believe it's important to have them a bit off from fully straight as otherwise when you look at the car it will look off.
Best thing is to mask it up and see for yourself what you like best
Old Jun 14, 2011 | 09:51 AM
mr_velocity's Avatar
mr_velocity
Do not use the same width, it will look like crap. Follow the dimensions posted.
Old Jun 14, 2011 | 02:02 PM
67Eleanor's Avatar
67Eleanor
ok i will try to press my painter in doing that i agree with you , thank you all very much for your help so far
Old Jun 20, 2011 | 06:27 AM
67Eleanor's Avatar
67Eleanor
Any information about the side stripes ??? so far all i got is the dimensions from mustang depots website .
poke68
Dec 16, 2025 03:36 PM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
orangeboom
Sep 23, 2015 09:43 AM
Mr. D
Sep 16, 2015 11:04 PM
unit91
Sep 15, 2015 09:53 AM
