New A/C causing overheating (w/pics)
Old Jul 18, 2011 | 11:42 AM
scottybaccus's Avatar
scottybaccus
It looks to me that your fan is inside the shroud. This could have the effect of throwing air from the center of the fan out the edge of the fan, but into the shroud, stalling flow-thru. If you fan has a frame all around than would prevent that, it is really only pulling from the diameter of the fan. Move the fan back a half inch.
Just because you have a shroud, doesn't mean it isn't your problem.
Old Jul 18, 2011 | 12:01 PM
wgc68nyc's Avatar
wgc68nyc
Since the shroud was made to have the fan inside would you recommend I flatten the shroud so it is almost against the rad fins (lil gap so no direct heat transfer) and then mount my new Spal on the outside?
Old Jul 18, 2011 | 03:37 PM
scottybaccus
I would try to leave the gap as is, but get the fan on the back side of the metal.
Think of it like you are building a vacuum cleaner.
Old Jul 18, 2011 | 04:05 PM
wgc68nyc's Avatar
wgc68nyc
I added a new pic so you can see I have maybe an inch or so of space but not enough to mount the existing fan (Spal will prob be the same) on the outside.
Options:
1) use a fan gasket or pads to move the fan out a little (but then it wont be flush against the fins) so it will stick out of the shroud more
2) remove the shroud and cut it so that the edges are not under the shroud (maybe 1/2-1in increase in diameter)....this will make the shroud unreturnable
3) Maybe the pulley wheel on my waterpump is replaceable with something that doesnt stick out so far
http://sitesearch.cjponyparts.com/se...er_pump_pulley
4) somehow rig a Dyson vaccum in there for max cooling power!!!
BOB ROME
Jul 26, 2023 01:54 PM
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
GLOCKer
Sep 28, 2015 07:36 AM
