aod conversion
Old Sep 1, 2011 | 11:31 PM
Vikefan88's Avatar
Vikefan88
Default aod conversion
Im planning on doing a aod conversion on my 65 stang.. will my torque convertor on my c4 fit an aod? thanks guys
Old Sep 2, 2011 | 01:13 AM
andrewmp6's Avatar
andrewmp6
I doubt it will work they are two different trans.
Old Sep 2, 2011 | 07:46 AM
KMatch's Avatar
KMatch
The AOD uses a converter designed for 2 inputs. 1 and 2 are on one shaft and 3 and 4 are on another. No other converters will work without trans modifications.
Old Sep 2, 2011 | 02:53 PM
PaulS's Avatar
PaulS
You need to get a flexplate, converter and new crossmember for the AOD.
You will also need cooler lines, throttle pressure lever kit for the carb, and an auxillary cooler.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
CarrieS
Sep 1, 2015 01:00 PM
