bad bad news....
Old Sep 4, 2011 | 01:45 PM
MustangFTW
Guest
Posts: n/a
Default bad bad news....
so i think i solved my engine not turning over problem, its most likely the TC not being seated correctly, it was a real bitch getting the tranny mated to the engine, at this point im just hoping i didnt destroy my transmission.
should i install the TC into the transmission first, make sure its fully seated then mate it to the engine?
Old Sep 4, 2011 | 02:10 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes...you spin the torque converter when installing it...you will hear it click and push back a couple times with a c4 more with an AOD etc...if you dont do this then install the tranny you can crush the front pump...
Old Sep 4, 2011 | 03:06 PM
MustangFTW
Guest
Posts: n/a
ya im worried ****less about this right now, hopefully it didnt crush it. i just took off the driveshaft and will pull the trany tomorrow.
would i be able to replace the pump itself or is the transmission scrap if its crushed?
Old Sep 4, 2011 | 03:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you can replace components fairly easily in a c4 transmission
Old Sep 4, 2011 | 03:30 PM
MustangFTW
Guest
Posts: n/a
thanks, i couldnt really find a solid lead on where to buy a pump if i crushed it. any suggestions?
Old Sep 4, 2011 | 04:13 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
id probably get one out of a junkyard tranny....
Old Sep 4, 2011 | 08:28 PM
JMD's Avatar
JMD
Don't worry about it yet, chances are the pump is ok.... I have seen this done a few times and never saw a pump ruined yet....
ALWAYS install the TQ on the tranny before installation......
Old Sep 4, 2011 | 10:29 PM
TexasAxMan's Avatar
TexasAxMan
When you take the trannyh out, check the flexplate for straightness. I'd be more worried about it than the pump.
Old Sep 5, 2011 | 03:41 AM
andrewmp6's Avatar
andrewmp6
Wait for paul he probably can get you just the pump if you need it.
Old Sep 5, 2011 | 10:01 AM
MustangFTW
Guest
Posts: n/a
cool. I should have it out today.
