wheels, tires, axles.
Old Oct 12, 2011 | 10:21 AM
rusty65's Avatar
rusty65
Default wheels, tires, axles.
Hey guys,
Ive recently started looking into new wheels and tires for my 65 coupe, but im concerned. Did all mustangs up till the mid 70s come with the 4 lug pattern, or did only the 6 cylinder mustangs come with the 4 lug and the v8 get the 5 lug? (Id just go look but ive got it parked in my garage back home and im at college) Also, if its the 5 lug then i need 5 x 4.5 lug pattern correct?
Once ive got the lug pattern figured out ive got to get the other dimensions down. I know 15" is the standard rim diameter, but have any of you gone 16"? Are there performance implications? Does it limit my range of tires? Id like to get a 16" rim, but id be happy with a 15" if it meant id have an easier time going about this whole process.
Finally, what size tires do you guys generally run? I want to get a nice wide tire for the back, but i dont know what i can fit in there with all the other stock components. In fact, an all around bigger tire would be nice (taller / wider than stock) - something to fill up the wheel well a bit more. But then this leaves me with the dilemma of the front tire. I dont want a skinny tire like ive seen on lots of the older mustangs and camaros, i want something almost the same size as the rear tire. Maybe not as wide, i just dont want it to look too disproportional.
Any thoughts or pictures or anything you guys have would be greatly appreciated.
Old Oct 12, 2011 | 10:51 AM
Gun Jam's Avatar
Gun Jam
4 lugs for I6 and 5 lugs for v8s
Old Oct 13, 2011 | 12:57 PM
lefty3382's Avatar
lefty3382
https://mustangforums.com/forum/clas...de-height.html
Old Oct 13, 2011 | 03:20 PM
Jonk67's Avatar
Jonk67
The backspacing (bs) on the rims you choose is what will place the tire the correct depth in the wheelwell, can't say for sure for '66 but '67 requires 4"-4.25" for best fit with 15" wheels. I believe the issue with 16" is that the rim may contact the UCA lip by the ball joint if it's the wrong bs. I think 215 is the max width for a front tire before you start rubbing the fender lips and while turning. I use 225's on my '67 but rolled the fender lips.
Jon
Old Oct 14, 2011 | 12:56 AM
andrewmp6's Avatar
andrewmp6
64-70 inline 6 but for the 69/70 250 inline 6 was 4 lug and the rear end was a 7.25 where the v8 cars 5 lug and a 8 inch or 9 inch rear end.
Old Oct 16, 2011 | 12:05 PM
rusty65's Avatar
rusty65
Alright, thanks for all the help guys! I think im going to stick with 15"x7" in the front and stick a 15"x8" in the back going off the info supplied in the link lefty gave.
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
mungodrums
Sep 28, 2015 05:45 AM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
