Traction bars
Old Oct 18, 2011 | 09:44 PM
Couper's Avatar
Couper
[QUOTE=P Zero;7724126]I used to have some lakewood traction/ladder bars back in the day, those things were sweet. My car would lift up an inch when I'd romp on it. No hop --ever!/QUOTE]
old school baby,....had to have the universal Lakewoods
Old Oct 19, 2011 | 02:12 AM
tx65coupe's Avatar
tx65coupe
I've got the black Lakewood slapper bars on mine. They are the ones that act as the spring/shock mounting plate. I have no wheel hop at all. I needed mounting plates that would work with the 3 inch axle tubes on the Versailles rear end. This worked out nicely. At some point I may switch, but for now its fine.
Old Oct 19, 2011 | 09:09 AM
MonsterBilly's Avatar
MonsterBilly
Suicide, I sent you a PM.
Old Oct 19, 2011 | 11:12 AM
frdnut's Avatar
frdnut
I am not a fan of the traction master type bars for a couple of reasons..First I don't like modifications that aren't reversible and they are weld on....The second is the bar and the leaf spring travel on different arcs so the suspension binds up...
Old Oct 19, 2011 | 12:33 PM
Iskwezm's Avatar
Iskwezm
I agree and the Cal Tracs are adjustable. Everycar is not the same nor is every track, so how could a "fixed" traction bar work for all situtions?
Old Oct 19, 2011 | 12:35 PM
palerider's Avatar
palerider
With your set up you don't have subframe connectors?
Old Oct 19, 2011 | 02:45 PM
urban_cowboy's Avatar
urban_cowboy
Caltracs are nice. Personally, I love my Slide-A-Links which are very similar but use a rubber bushing to help lessen the shock when you dump the clutch. Since installing them, I never have wheel hop. Now I have plenty of tire spin on the street and even 60-70' on the track, but never hopping.
IMO, slapper bars are junk from the the early days.
Old Oct 21, 2011 | 12:40 AM
frdnut's Avatar
frdnut
There are many different brands of slapper bars..Some are junk like the ones that just clamp to the spring and have the rubber snubbers about 3 inches below the springs so they never make contact...A properly setup slapper bar can work very well though..
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
