Fan Relay
Old Oct 18, 2011 | 09:30 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Fan Relay
Ok so my Mark 8 fan showed up today and I've been reading that my relay isn't good enough. I currently have a 30 amp relay, which has actually quit working. Any recommendations on what size relay setup I need to run? I don't want to spend a lot on the kit(< $100) since I've drained what little savings I had on other things.
Also, holy crap this fan is huge!
Old Oct 18, 2011 | 09:52 PM
wgc68nyc's Avatar
wgc68nyc
http://www.fordmuscle.com/archives/2...8Fan/index.php
this is the kit I use which turns on at 185
Mr Gasket thermostatic sensor part 1992 at advanced auto parts
http://shop.advanceautoparts.com/web...___#fragment-4
Old Oct 18, 2011 | 09:57 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah the current setup I have turns on at 185 and off at 170
Old Oct 18, 2011 | 10:11 PM
Gun Jam's Avatar
Gun Jam
Im sure it looks like a monster compared to that computer CPU cooling fan you were using
Old Oct 18, 2011 | 10:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah it really does. I wasn't expecting it to be this big
Old Oct 18, 2011 | 10:55 PM
scottybaccus's Avatar
scottybaccus
I recently installed one using a common 70 amp SPDT relay. It's a Delco kit that comes with the pigtail and socket for about $50. Not cheap, but high quality. Usually in stock at Carquest. Just ask for it.
It allows you to operate a 70 amp fan load from a generic temp sensor. The sensor I used comes from late '80s Mopars. It has a 3/4 npt thread and two male spade terminals for you to plug onto. It cuts on/off around 178*.
Wire the fan through the relay with a good sized fusible link at the battery. Wire the relay through an ignition hot fused inside the car. This way the fan could short and it will be disconnected when the fusible link fails and no wiring inside the car is at risk. If the relay shorts, it will pop the fuse on the ignition hot circuit.
Use a second one for A/C activation of the fan and you get the bonus of having a redundant relay that can be swapped in if the primary should fail.
Old Oct 18, 2011 | 11:59 PM
Iskwezm's Avatar
Iskwezm
We (PAC) have a 80 amp relay(p/n pac80).I didnt use one because I didnt work for the company at the time, so paid about 45 bucks for a 70 amp relay.No controller,no sensors, just a switch to a relay.Has worked great for about 7 years now.
http://www.onlinecarstereo.com/CarAu...ice_Comparison
Old Oct 19, 2011 | 07:43 AM
1slow67's Avatar
1slow67
ROTM Moderator
I've got a 40 amp circuit breaker connected to the battery that then goes to my relay setup.
Old Oct 19, 2011 | 07:48 AM
1slow67's Avatar
1slow67
ROTM Moderator
Thanks, just ordered it off of Amazon. I get free 2 day shipping, so hopefully I can get this running before my car show sunday.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
Sep 25, 2015 09:06 AM
