Thoughts on this Leak??
Old Oct 22, 2011 | 04:34 PM
ChameleonAlley's Avatar
ChameleonAlley
Default Thoughts on this Leak??
After my car gets good and hot, a drive around town, I noticed it started leaking. I took a video of it, hoping it would help, but I'm not sure where it's coming from. It's right by the spark plug, but I can't tell if it's the plug or the exhaust manifold. When I rev it, smoke spurts out. Thanks all!!
http://www.youtube.com/watch?v=dwaztSsv1u0
Old Oct 22, 2011 | 06:02 PM
scootchu's Avatar
scootchu
I would have to say its probably oil dripping from a leaky valve cover.
Old Oct 22, 2011 | 06:13 PM
ChameleonAlley
Thanks for the input!! It visually looks like it's coming from the spark plug or right under it. I don't see any oil. It's just popping smoke out.
Old Oct 22, 2011 | 10:50 PM
MonsterBilly's Avatar
MonsterBilly
if you find it let me know. mine does the same thing. im too lazy these days to track it down.
Old Oct 23, 2011 | 12:43 AM
ChameleonAlley
Ha! I hear you. I went and tightened down all the valve cover bolts. They were all pretty loose. I took it for another drive to see if it happened again, and it did. I'm starting to think it's a leak in the exhaust manifold connection to the engine. Still not sure... There's no reason the spark plug would puff smoke is there?
Old Oct 23, 2011 | 01:11 AM
eZ's Avatar
eZ
WHat does it smell like? I would chenge your valve cover gaskets. It smokes when it drips onto exhaust manifold. shouldnt smoke out the spark plug.
Old Oct 23, 2011 | 01:59 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
is your spark plug screwed down?
Old Oct 23, 2011 | 10:03 AM
ChameleonAlley
I'm going to check the spark plug today. Is it even possible for a spark plug to spit smoke?
Old Oct 23, 2011 | 10:53 AM
MustangFTW
Guest
Posts: n/a
make sure it isnt leaking from around the bolts that hold the valve cover in place. that has happened on mine before.
Old Oct 23, 2011 | 05:49 PM
JMD's Avatar
JMD
It seldom happens with the sparkplugs they make today, but the ceramic CAN separate from the steel and allow a combustion chamber leak..
