just finished paint :)
Old Jan 24, 2012 | 04:15 PM
  #31
guitarman376's Avatar
guitarman376
Wow....freaking awesome car. Stance looks awesome in my opinion.
Old Jan 24, 2012 | 05:20 PM
  #32
68dustin's Avatar
68dustin
thanks everyone.. i've put alot of hours into it..
Old Jan 25, 2012 | 07:41 AM
  #33
SILVER5.0's Avatar
SILVER5.0
Originally Posted by 68dustin
The gun was a hvlp, here is the link.. http://www.tcpglobal.com/autobodydep...emno=TCP+G7000
Thanks!
Old Jan 26, 2012 | 09:36 AM
  #34
Couper's Avatar
Couper
I'm as curious as many of the others,...give us a full run down of the paint prep, materials, buffing, garage set up etc,...
You've got many, many impressed readers that are very curious.
THANKS!
Old Jan 26, 2012 | 11:20 AM
  #35
hightower2011's Avatar
hightower2011
I admit I am curious as well. If it's not too much trouble, a short description of your work to get that beautiful finish would be greatly appreciated!
Again, it looks phenomenal!
Old Jan 26, 2012 | 02:30 PM
  #36
68dustin's Avatar
68dustin
1. Sharpe all dents on car
2. Work each panel 1 at a time - sand down with 60-40 grit at dent location
3. Fill with evercoat filler
4. Knock down to get "general shape" of car with filler
5. Finish dents with 120-180 paper to feather and smooth out filler
6. After all dents are done, i then began sanding car down (took some spots to metal)
8. Washed and blew out all cracks with compressed air.
9. Wiped car down with wax*grease remover (wear gloves - no skin contact to car)
10. Sparyed the whole car with http://www.tcpglobal.com/restoration...+KIT-KEP506-GL one qt. will do 1 coat pretty easy
11. Found a few more dings, and fixed (you can lay filler over epoxy primer)
12. Cleaned and wax removed car again
13. Bought a gallon & Put 1 coat of : http://www.tcpglobal.com/restoration...=KUS+KPP106-QT This stuff has great filling properties (sanding scrathes ect.)
14. Blocked entire car again with 200 - the black primer after sanding shows the dings really good. The car turns a dark gray after sanded.
15. Repeated the dent fixing process lol, always more dings
16. Repeated cleaning process again
17. Put another coat of primer on car and blocked out with 400 this time. Do not use anything lower or scatches will appear in paint.
18 Repeated cleaning process AND WEAR GLOVES NO SKIN CONTACT ON CAR
19. Taped off car and painted jambs
20. Waited a week and taped off jambs to paint car
21. Blow off car and wipe down with wax grease remover
22. Wipe car down with tack rag
23. Mixed up paint: http://www.tcpglobal.com/restoration...P+UB2701-KIT-M I made sure the garage was at least 70 and all pilot lights were blown out
24. Put 4 coats of base (tack rag in between coats)
25. Put 3 coats of clear (no tack rag)
26. After a week and half i started cutting and buffing. here is the kit i used, pretty beginner friendly. Not the best, but im a noob. http://www.summitracing.com/search/B.../?autoview=SKU
Basically wet sanded and buffed each panel at a time. 2000-2500 sand paper. Took about 2hrs for each panel. (so ya... alot of hours)
Im sure this little write up wont be perfect for some people, but hell I learned everything off reading what people have posted. Asked alot of questions and never went to any autobody school. That and total cost of paint job was around 450.
** my write up was more indepth, but computer crashed and had to start over.. sorry hope this helps
Old Apr 25, 2012 | 10:41 AM
  #37
68dustin's Avatar
68dustin
Old Apr 27, 2012 | 01:24 AM
  #38
ThetaTau87's Avatar
ThetaTau87
Very nice. Looks great!
Old Apr 27, 2012 | 06:13 AM
  #39
palerider's Avatar
palerider
Nice write up and excellent job - my car is in paint stage. Probably will hire out - but if too costly I may try it.
BTW what size wheels do you have nice look.
Old Apr 27, 2012 | 07:50 AM
  #40
69FB's Avatar
69FB
Looks great! Once I get to paint I might try this myself. Just a long ways from paint right now.
