exhaust manifold vs headers
Old Nov 15, 2011 | 08:23 PM
Toastintx's Avatar
Toastintx
Default exhaust manifold vs headers
ok guys is there really a whole lot of difference between stock manifold, 289 hi pro manifold, and headers. i hve cheap headers on now 302, i had to dent in the tube a little for the shock tower. should i go back with stock or hi pro? hows the sound difference and performance
Old Nov 15, 2011 | 08:57 PM
MustangFTW
Guest
Posts: n/a
Firstly, it's Hi-Po.
Now denting any thing on an exhaust is no good since it kills the flow. If you do headers I would only do long tubes which can be nasty to get on and are expensive. I say go with the 289 HiPo manifolds. While your at it you can remove the heads and port them for a nice gain if you would like.
Old Nov 15, 2011 | 09:02 PM
frdnut's Avatar
frdnut
Long tube headers are much better than manifolds when it comes to performance..The HI-Po manifolds are not much better than the garden variety units..
Old Nov 15, 2011 | 09:08 PM
jojobanks's Avatar
jojobanks
this...
i would have dented the shock tower before the headers
Old Nov 15, 2011 | 09:12 PM
MustangFTW
Guest
Posts: n/a
HIpos might be better then the cheap headers. As said above long tubes are the way to go, the newer mustangs see gains of 20rwhp from them, if you port the heads I wouldn't doubt a bigger jump from a 289. Be prepared to curse yourself to hell and back when installing them. :-P
Old Nov 15, 2011 | 10:14 PM
JMD's Avatar
JMD
I know some disagree, but I despise long tube headers on most cars, they can be a pain in the *** to fit, they often drag the ground on a Mustang, and the good ones are damn expensive.
All in all, I say a good ceramic coated mid length header or HIPPO manifolds for a classic Mustang. If you aren't looking to extract max power from your engine, then manifolds might be the way to go.
My son just bought HIPPO manifolds for his 64 Falcon, he has gotten tired of messing with his mid length headers, and I don't blame him.
Sometimes "compromise" is the smart move.
Old Nov 15, 2011 | 10:27 PM
andrewmp6's Avatar
andrewmp6
Good headers are great but not cheap if you buy cheap ones they don't fight right and will leak over time.
Old Nov 15, 2011 | 11:00 PM
67mustang302's Avatar
67mustang302
If you're not willing to spend the money on good headers, don't whine about performance and fitment. Good parts cost good money, period.
Old Nov 16, 2011 | 06:27 AM
Toastintx's Avatar
Toastintx
thanks for the input guys, I think im leaning toward the manifolds. is there that much diff in stock compared to HIPO, i know i just asked the same ? but headers are out
Old Nov 16, 2011 | 08:43 AM
mr_velocity's Avatar
mr_velocity
Haven't heard a single complaint about these headers, including those that have installed them with a 4R70W. http://www.fordpowertrain.com/FPAindex/FPA%20index1.htm
