engine wiring
Old Dec 4, 2011 | 07:03 PM
oxfordbp's Avatar
oxfordbp
Default engine wiring
as posted in my other threads, I have a 68 I6 converted over to 302. The wiring is obviously I6, what do I need to change to properly wire up my V8 motor? Can I get just a V8 engine harness and replace the 6?
Old Dec 4, 2011 | 07:15 PM
jp1967stang's Avatar
jp1967stang
Just the engine feed harness.
Old Dec 4, 2011 | 07:28 PM
oxfordbp's Avatar
oxfordbp
Awesome. Does it plug into the fuse box separately? is that the only harness in the engine bay besides the head light one?
Old Dec 4, 2011 | 07:29 PM
1slow67's Avatar
1slow67
ROTM Moderator
What wiring is needed? I coverted to V8 and all I did was add length to a couple of wires.
Old Dec 4, 2011 | 07:38 PM
oxfordbp's Avatar
oxfordbp
Everything. Wouldnt it be cleaner to replace the whole harness? I also need the starter wired, alternator, and battery leads...
Old Dec 4, 2011 | 07:48 PM
MustangFTW
Guest
Posts: n/a
If you have the six harness you could re use it, just clean up the wrapping with some new stuff.
Old Dec 4, 2011 | 07:57 PM
1slow67's Avatar
1slow67
ROTM Moderator
All of my wiring was in the correct location, except for temp and oil pressure. I did mod my harness and move my alternator to the drivers side and put my A/C compressor where the alternator went.
Old Dec 4, 2011 | 08:01 PM
oxfordbp's Avatar
oxfordbp
Hmm....Just thought a new one would be better than splicing, but then I could customize it more...
Old Dec 4, 2011 | 08:02 PM
1slow67's Avatar
1slow67
ROTM Moderator
Its up to you, I did mine on a low budget and didn't see a reason to replace anything. However, mine is not a show car its a DD, so no one really ever sees the engine bay.
Old Dec 4, 2011 | 08:04 PM
MustangFTW
Guest
Posts: n/a
I would unwrap the old one, check for any cracks, take measurements, splice in new wire, re wrap and voila. New harnesses are pricey too.
