Recommendations Please
Old Dec 28, 2011 | 07:34 PM
67 evil eleanor's Avatar
67 evil eleanor
"OCHOHILL" is right. For a very few more bucks (roller spring perches and drill bit) you can do these mods and have a great driving car. The labor is pretty intense to change the suspension as compared to the offset in cost. Also, get a good alignment after the change.
Old Dec 28, 2011 | 11:57 PM
oxfordbp's Avatar
oxfordbp
Im just going to replace the upper ball joints for now. That will at least get me on the road safely.
I might already have the 620's on there cause she sits pretty low already. I will look into the UCA drop later.
I just want to drive it so I can start diagnosing issues! 40$ fix for now aint a bad start!
Thanks for all the info.
Old Dec 30, 2011 | 10:48 AM
OCHOHILL's Avatar
OCHOHILL
To do it correctly is more than $40. Each time a part is changed an alignment should be done. That is one reason most do it all at once. Not performing an alignment could lead to uneven tire wear and poor handling.
Old Dec 31, 2011 | 03:24 AM
oxfordbp's Avatar
oxfordbp
I never thought of that. Maybe I will just do it all at once.
The stock replacement kits all come with riveted ball joints. Is this ok? If I need to replace them later would I just drill them out?
I already ordered my Shelby drop drill bit and template!
Old Dec 31, 2011 | 07:00 PM
jojobanks's Avatar
jojobanks
riveted ball joints aren't a big problem. A lot of companies use rivets instead of actual bolts/nuts to save pennies, but it's easy enough to drill the rivets if you need to. Personally I've never had a problem with it.
Old Dec 31, 2011 | 08:47 PM
oxfordbp's Avatar
oxfordbp
That's what I figured but wasn't Thanks
Old Jan 1, 2012 | 11:00 PM
oxfordbp's Avatar
oxfordbp
Check this kit out!!
http://www.ebay.com/itm/380398866798...ht_2908wt_1270
I can upgrade to the roller perches later. I tried to swap to them in the kit but they dont offer them.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
UrS4
Sep 30, 2015 10:13 AM
nboost
Sep 16, 2015 05:35 AM
