Rear Axel Information
Old Sep 12, 2005 | 03:19 PM
pak133's Avatar
pak133
Default Rear Axel Information
This weekend I plan to pull the drive train, if I get the opportunity. In doing a visiual inspection I noticed that my rear axle seems to be leaking a small amount of fluid. I plan to pull the rear end, redo the seals, gasket and fluid and the clean and repaint it. Maybe not all this weekend but I was wondering if anyone has gone through this process and if there were any cautions they might want to throw out. Thanks.
Phil
Old Sep 12, 2005 | 03:31 PM
harald's Avatar
harald
Default RE: Rear Axel Information
not really, just that i used loctite gasket on mine and it never leaked since. ow yeah, and to clean it out i used powerclean or brake cleaner, works great. finish off with a high pressure lube additive and you're laughing.
good luck.
ps, when you pull the drive shaft out, be aware that there will be oil coming out of the tranny. they sell plugs to go in there, but i put a rag in there and taped it up with duck tape, and that 'll hold for a while (not weeks).
Old Sep 12, 2005 | 03:34 PM
pak133's Avatar
pak133
I have a 3 speed....will I still have an oil leakage problem? Or is that more of a problem with automatics?
Thanks
Phil
Old Sep 12, 2005 | 03:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you are only working on the differential, you just need to take the driveshaft off at the yoke on the differential. Why bother taking it off at the tranny? Or, are you planning to pull the tranny also?
Old Sep 12, 2005 | 04:00 PM
pak133's Avatar
pak133
The entire drive train is coming out. I'm going to rebuild the tranny, and clean and paint the drive shaft. Again, not this weekend but at some point.
If you're going to be a bear...you might as well be a grizzly!!
Old Sep 12, 2005 | 04:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
You won't get any leakage with the 3 speed unless the rear yoke seal is damaged.
Old Sep 12, 2005 | 04:03 PM
pak133's Avatar
pak133
I kind of figured that...thanks.
67LimeCoupe
Sep 30, 2015 04:46 PM
04stangman
Sep 26, 2015 09:33 AM
wishinsky
Sep 21, 2015 09:48 AM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
