My poor Christine, please help
Old Sep 17, 2005 | 03:21 PM
  #21
uwti's Avatar
uwti
Default RE: My poor Christine, please help
You may need to have the carb re-jetted!!
Old Sep 17, 2005 | 03:30 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
Nah, she's getting a new carb.
Old Sep 17, 2005 | 03:35 PM
  #23
newownerof72's Avatar
newownerof72
Hi Everybody...
Got the Chilton and the carb and are in the process of replacing diz cap, rotor, condenser and points. Got the feeler gauge and the timing light and as soon as the hubby gets home we are gonna work on her.
Oh yeah, and we have to fix another leak in the radiator
Old Sep 17, 2005 | 05:48 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
Good. Set those points to right at 0.017 and the timing at 8-10 degrees BTDC.
Old Sep 19, 2005 | 08:12 PM
  #25
newownerof72
The manual and instructions for the timing light say we have to set the RPM at 500 before we can set the timing. So we are looking for a tach now, the hubby was going to buy the biggest one he could find just to aggravate me, but I think I talked him outta that. Anyhow, we have tried it at 7 and 10 and the points at .018 but that was a no go. Dad said that .016 may be better than the .018 or 7 even. So I think that all we are waiting on is the tach so we can set the rpm correctly and try 6 BTDC which is what the manual says.
Its been three dang weeks and i am starting to lose my patience, i hope to god this works.
Old Sep 19, 2005 | 08:15 PM
  #26
tylerdru's Avatar
tylerdru
Take your radiator to the radiator shop. They will fix any leak, paint it, and clean out the inside.
for $50
Old Sep 19, 2005 | 10:04 PM
  #27
73Cleveland's Avatar
73Cleveland
ORIGINAL: tylerdru
for $50
You can take it to a shop if you have one you can trust. I personally would rather get a new one. Around here the new one has a better warranty than a rebuilt or patched one. It may cost a bit more up front but it sounds like you have a pretty bad radiator.
Soaring was right on with the points at .017. You can also safely set the timing further to around 8 degrees BTDC without any problems. If you get any engine ping, back it back down to 7 or 6 then.
Old Sep 20, 2005 | 04:23 AM
  #28
KBunny's Avatar
KBunny
So I take it the carb didnt fix it?
Old Sep 20, 2005 | 04:45 AM
  #29
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: newownerof72
The best timing light in the world is your ears. Set it close to about 8, then take it out on the road and see if it pings. Tweak it from there. Be sure you plug the vacuum line with a screw or something while you are timing it. Timing also has to do with the quality of gas you have in it. Are you running 91-93 octane? If not, then you should.
Old Sep 20, 2005 | 08:22 AM
  #30
tylerdru's Avatar
tylerdru
91-93 octane is just regular gas right? If not then i will cry.
