Aod...LOL
Old Sep 17, 2005 | 12:51 AM
eZ's Avatar
eZ
Default Aod...LOL
well i figured out that the flex plate on the c4 is a wee bit smaller than the aod which is why i have not been able to bolt it up...but i ran into another problem, the thing doesnt quite fit into the transmission tunnel...do i need to make a dent in the tunnel to make it fit...it would be a small dent bout the size of half a baseball...and also i cant seem to find the linkage that someone already make from the shifter to the tranny. i was thinking of getting some aluminum tubbing and bending it by hand until i had the bends i need to make the shift linkage work the fabricated my own out of steel. any suggestions?
p.s.
sad think is i have all the parts in my garage to finish this whole car, right down to the stereo. just keep running into speed bumps.
Old Sep 17, 2005 | 03:56 PM
69mach1377's Avatar
69mach1377
Default RE: Aod...LOL
Be very careful with the TV cable IIRC, you can toast your AOD in one block in not done correctly.
Old Sep 17, 2005 | 07:50 PM
eZ's Avatar
eZ
are you talking about the electronics conversion?
Old Sep 18, 2005 | 08:09 PM
69mach1377's Avatar
69mach1377
Nope...that would be an AODE. I don't know all the details, but I would if I were you. Maybe someone else does?
