Stripped lug nut key & nut
Old Apr 11, 2012 | 08:42 AM
dmaclaren's Avatar
dmaclaren
Default Stripped lug nut key & nut
What do I do? There is a number on the key, can I get another? where do I do that if I don't know what brand it was? Do I have to wait until it's together to take it to a shop?
I think going forward they can steal the damn wheel, I assume taking the car is easier than taking the wheels, I knew when I bought it I should have removed them.
Any help is appreciated.
Old Apr 11, 2012 | 08:47 AM
dmaclaren's Avatar
dmaclaren
I guess now that I have a mig I could weld on a nut and try that.
I also saw someone have a socket pounded on the nut.
hmm, I do have a ton of extra sockets I could also weld, that is if steel under so I could tack.
Old Apr 11, 2012 | 09:45 AM
boogerschnot's Avatar
boogerschnot
Take it to a tire shop, they have a tool that bites onto the outside of the nut and takes it off.
Old Apr 11, 2012 | 11:20 AM
rtintwo's Avatar
rtintwo
This is your cheapest option now that you have the welder.
Old Apr 11, 2012 | 02:35 PM
smodat's Avatar
smodat
You could get a set of bolt extrators for about $20-$30 and it will take the lug nut off, plus you could use them for other rusted bolts and nuts.
[IMG]c:\users\scook\desktop\bolt extractor.jpg[/IMG]
Old Apr 11, 2012 | 02:40 PM
smodat's Avatar
smodat
Sorry, the pic didnt show up in the previous post, here is a link to an example of what I'm talking about, you wouldnt need an expensive set unless you planned on using them quite a bit.
http://www.irwin.com/tools/screw-bol...olt-extractors
Old Apr 11, 2012 | 02:46 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Or if you have access to the lug stud from behind, grind the head down that holds it to the hub and pop it out the other end (rim side) with an awl and a hammer. Replace the stud and buy a new lug.
Less likely to ruin the rim.
Old Apr 11, 2012 | 11:04 PM
JMD's Avatar
JMD
Try driving an old socket up on that nut... chances are fair that this will get it done.
If this wont work, they make socket for this express purpose, they don't cost a fortune. I bought an SK set a few years ago, they work great unless the nut is recessed in a narrow hole...
Old Apr 13, 2012 | 10:15 AM
TommyK's Avatar
TommyK
I went through this a couple of years ago when I lost the key. This worked fine.
http://www.autobarn.net/emlugnutrem....te=google_base
Old Apr 13, 2012 | 12:11 PM
MonsterBilly's Avatar
MonsterBilly
you can also try to hammer on a socket. That is what i did and it worked. never could get the nut out of the socket though
