Advice Needed for Doo Hinge Fix
Old May 15, 2012 | 11:40 AM
unit91's Avatar
unit91
Question Advice Needed for Doo Hinge Fix
The passenger door hinge on my 68 needs to be fixed/replaced. I have a bushing/pin kit in case it can be repaired instead of replaced. I understand there's 3 ways to approach this in order to get to the bolts: 1 - remove fender; 2 - remove door; 3 - cut pin with door and fender in place and install new bushing and pin if the hinge isn't too worn out. I bought a SnapOn S-wrench but even with that I can only get to 2 of the bolts, and I can see that I'm going to chip some paint if I'm not careful. Since I have no one to help me with this, which method would you suggest? You guys have the expierence in this that I don't. Thanks!
That would be DOOR hinge - not DOO..........sorry.
Old May 16, 2012 | 03:01 PM
jlg2002's Avatar
jlg2002
I removed the bottom fender bolt so i could pull the fender out far enought to get a flex socket on the hinge bolts on my 66.
Old May 16, 2012 | 03:05 PM
unit91's Avatar
unit91
Never thought of that! I'll see if I can do that without damaging the paint. I already chipped it trying to use a wrench - even with masking tape over it. Thanks.
djbigskrilla
Sep 20, 2022 01:04 AM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
defarmer
Aug 13, 2015 06:40 AM
