New engine installed...
Old May 17, 2012 | 07:14 PM
eZ's Avatar
eZ
Default New engine installed...
Bought a short block from TRE performance...took 2 full days to get motor into the 65. Started it up and oil is pouring out the rear dripping down the beel housing...did these bastards not install a galley plug or maybe even the rear main seal? Now I have to spend a full day pulling it out, and then another putting it back in again. What else could have been forgotten? I am beyond pissed. Everytime I rely on someone elses work I get ****ed.
Old May 17, 2012 | 08:16 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Is it possible that you got a rear intake manifold oil leak?
I've replaced several intakes in the past doing 4V upgrades and I've also taken a couple back off because a oil leak you mentioned.
That was when I got smart and started studding my 4 corners of the manifold so that I knew 100% it dropped straight down and never shifted and moving gaskets while placing it on.
I'd look into that before taking the whole motor out.
Lynn
Old May 18, 2012 | 01:53 AM
Boxwrenchesareslow's Avatar
Boxwrenchesareslow
yes, sounds like you got a bad rear main seal probably.. a galley plug left out would leak a ton of oil.
good, idea with the intake studs. I like to put a stud in the center of each head, then pull them out once you got the rest of the bolts in.
Old May 18, 2012 | 06:33 AM
LynnBob Mustang
He mentions it dripping down the bell housing, so I was more inclined to the intake manifold.
Depending on how long the short block sat before it was sold, the rear seal could possibly have dry rotted a bit causing the leak.
Lynn
Old May 18, 2012 | 11:16 AM
OCHOHILL's Avatar
OCHOHILL
There is a large press in plug in the lifter valley near the rear intake valley seal. Heresay only, but I recall reading chevy guys forget that one from time to time.
BTW, All other galley plugs should have been tapped and plugged instead of using a press in plug.
I don't recall, what happened to the last motor?
One other thing, if it is the rear main, make sure there are no nicks on the crank use a viton seal (asssuming 1 piece here).
Old May 18, 2012 | 11:43 AM
Boxwrenchesareslow
hahah, ya the chevy guys love to forget that big one under the intake! With that out though, you will have zero oil pressure
Old May 21, 2012 | 01:53 PM
eZ's Avatar
eZ
I inspected the galley plugs before install. Weird that the fronts were screw in type and rears were press in. or vise versa. I highley boubt the intake would leak as bad as the oil was. And visually I would have been able to see the intake leaking. Im going to pull the motor today and prime the heck out of it to see if I can locate the problem if it is not obvious. Hoping its a gally plug but i bet its the rear main. Which is gonna suck because everything will have to come apart.
Old May 21, 2012 | 02:27 PM
Gun Jam's Avatar
Gun Jam
its not the two piece rear main that you tap out and slide in the new half?
Old May 21, 2012 | 06:52 PM
eZ's Avatar
eZ
So I pulled the motor and there is no rear seal installed. bought a new one and I cant get the SOB to tap in. Any tips. I greased it up
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
