starter install confusion?
Old May 23, 2012 | 09:25 PM
torinostroker's Avatar
torinostroker
Default starter install confusion?
so i got a new starter from Auto zone. i only see one bolt on the side of it for a wire is there not two? and where do you hook up the wires to on the starter if they come from a separate source.
Old May 23, 2012 | 09:31 PM
Randys66gt's Avatar
Randys66gt
The single cable goes from the starter (plug on side) and then goes up to the solenoid on the pass. side next to the battery. The Ignition goes to the right side and the crank goes to the left small nuts.
Old May 23, 2012 | 09:32 PM
torinostroker
it is a 71 ford torino 500 with a 302 BTW.
Old May 23, 2012 | 09:38 PM
Randys66gt's Avatar
Randys66gt
No prob. on your tach, red goes to a switched positive wire (only on with the key) black to ground, green to the negative side of the ignition coil and the white to a light wire.
Old May 23, 2012 | 09:45 PM
torinostroker
ok what do you mean switched positive wire. is that on the steering column.
Old May 23, 2012 | 09:50 PM
torinostroker
sorry meant to say it the spot for the red wire on the steering column?
Old May 24, 2012 | 01:22 AM
Randys66gt's Avatar
Randys66gt
Switched positive is when you turn the key to on, that is when you get power. Otherwise, no power
mtgldr
Feb 3, 2024 09:00 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
