Starter issue
Old Aug 9, 2012 | 09:33 AM
Gun Jam's Avatar
Gun Jam
your getting voltage sag because of high resistance or bad battery.
Do try running an engine ground
Old Aug 9, 2012 | 10:57 AM
MonsterBilly's Avatar
MonsterBilly
Yup, its Eli.da deffinatly like a bad ground.... Clean every connection again. And ground the block.
Old Aug 9, 2012 | 01:02 PM
oxfordbp's Avatar
oxfordbp
Will do guys thanks. Its not a bad battery though, im using the battery off of our jeep daily driver.
Old Aug 12, 2012 | 01:40 PM
oxfordbp's Avatar
oxfordbp
Okay guys, Im seriously getting fed up with this issue. It is the LAST thing I need to figure out before I can hear this beast run! I relocated the ground to the head, I took sand paper and wire brush to bare metal. I know the ground is good.
I still only get 6-7 volts to the starter side of the solenoid. AND when I jump the battery hot to the starter side of the solenoid I get a spark and the wire gets hot. If I hole the cable there for a few seconds i hear the starter spin but not pop out.
PLEASE lets figure this out. Im at a loss...
Old Aug 13, 2012 | 08:49 PM
putz54143's Avatar
putz54143
you should put a battery in the car i think not haveing a battery in the car and using cheap jumpers is giving you trouble
Old Aug 13, 2012 | 09:50 PM
oxfordbp's Avatar
oxfordbp
You are exactly correct!! I went and got a new battery today and she fired up no problem!!
Old Aug 13, 2012 | 11:26 PM
Gun Jam's Avatar
Gun Jam
going to save the i told ya so ;P or not
Im glad you got it dialed! happy driving
-Gun
Old Aug 14, 2012 | 01:17 AM
oxfordbp's Avatar
oxfordbp
-Gun
HAHA...Yes I am able to start her now, but lots more needed till I can drive!
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
logan409
Sep 26, 2015 07:43 PM
