How do i ground my Dash cluster?
Old Sep 25, 2005 | 07:00 PM
tylerdru's Avatar
tylerdru
Default How do i ground my Dash cluster?
How and where do i ground my dash cluster? What kind of wire do i need? This will solve my lighting problem! Please Help!
Old Sep 25, 2005 | 07:10 PM
6mustang6's Avatar
6mustang6
Default RE: How do i ground my Dash cluster?
Just run a wire, the same guage as the other ones. Connect to behind the regulator on the cluster. I believe thats where it's supposed to go. Then just ground it somewhere on the dash.
Old Sep 25, 2005 | 07:24 PM
tylerdru's Avatar
tylerdru
will this stop my cluster from sparking everytime it touches metal?
Old Sep 25, 2005 | 07:26 PM
6mustang6's Avatar
6mustang6
there must be a power wire connected to that cluster. Just for a test, hook up the ground wire and touch it to the cluster. More then likely it will spark. If it does, then there is a wire on the cluster, that is not hooked up properly or shouldn't be there at all.
Old Sep 25, 2005 | 07:27 PM
tylerdru's Avatar
tylerdru
okay
Old Sep 25, 2005 | 07:29 PM
6mustang6's Avatar
6mustang6
DId you say it does it only when the Temp guage is hooked up? If so, i would start looking there.
Old Sep 25, 2005 | 08:13 PM
tylerdru's Avatar
tylerdru
yeah the guy before us had the harness labeled wrong. I just got back from pepboys. We test the ground and that is indeed the problem. Im getting ready to solder my ground wire to some circle thingys that you use with screws. then i will have light. Pics to prove also!
Old Sep 25, 2005 | 08:43 PM
tylerdru's Avatar
tylerdru
OK They work now!!!!!!!!!!!
Id like to thank everybody that helpedme through a stupid topic. The problems were: the headlight switch was bad, harness not plugged in right, and cluster not grounded properly.
I sacrificed a nice battery and maybe a starter solenoid trying to fix this problem.
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
