377 Clevor is DED dead
Old Nov 7, 2012 | 12:42 PM
69mach1377's Avatar
69mach1377
Default 377 Clevor is DED dead
Seems to have spun the #3 rod bearing based on the loud knocking noise, smashed spark plug and that it won't hand turn beyond a certain point (where the piston meets the head?).
The default reaction is to rebuild what you got, right?
Not sure I can get replacement parts such as a narrowed 300 cid rod and bearings, crank and cut down 400M piston, assuming they are ruined. The company went out of biz years ago. I also don't see any stroked clevor rotating assemblies on the market, a 408 would be nice.
Any suggestions?
Old Nov 7, 2012 | 02:37 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
A FoMoCo 392 crate would be oh so sweet
...disregard. I just took a gander at the 2012 Ford Racing catalog and they no longer offer the 392. They stroked the hell out of a 302 to 363 for a cool 8600.00 for a long block and 5k for the short block.
gack.
Old Nov 7, 2012 | 02:50 PM
toybreaker's Avatar
toybreaker
If the block isn't damaged beyond use, trash the rotating assembly and buy a 408 rotating assembly. All off the shelf parts now....
Old Nov 7, 2012 | 03:16 PM
69mach1377's Avatar
69mach1377
All the 408 kits I've seen recently are either W or C, not Clevor (C heads on a W block).
Or am I missing something?
Got a source for a 408 Clevor rotating assy?
Old Nov 7, 2012 | 03:18 PM
69mach1377's Avatar
69mach1377
gack.
Yeah, that kind of moolah ain't gonna happen for this.
Old Nov 7, 2012 | 07:17 PM
toybreaker's Avatar
toybreaker
The only difference between the clevor and windsor would be the valve reliefs. any good automotvie machine shop can do it. Hell if i was close I would do it for you.
Old Nov 7, 2012 | 10:39 PM
69mach1377's Avatar
69mach1377
Guam is a bit far, but thanks for the offer.
Old Nov 8, 2012 | 08:15 PM
toybreaker's Avatar
toybreaker
Home was Phoenix before the navy sent me here....
Old Nov 9, 2012 | 06:26 AM
kenash's Avatar
kenash
Hi,
I like to think you have this block apart by now to determine the cause and next steps...
Good Luck
Old Nov 9, 2012 | 10:07 AM
69mach1377's Avatar
69mach1377
Originally Posted by kenash
Hi,
Good Luck
Thanks,
Probably not until January. But here some options I've thought about.
Option 1 (same as before, but maybe not stroked)
• Get it running asap by rebuilding the current Clevor engine
• Assumes the block, heads/valves and cam/lifters/chain etc. are not damaged
• Might not be able to use the 377 rotating assy (assume #3 is non-repairable)
o Would need new rotating assy (358?)
o May need smaller carb if not stroked? Re jet only?
o May need to bore out to .040”?
• Restore engine compartment while engine is out
o Fix heater fan/controls
• Decent resale value, will still need paint and body for the most part, may come out ahead
• Cost = I&R, ? parts + ? labor. Mike to provide quotes.
Option 1a (same as before, but stroked even more)
• Might not be able to use the existing 377 rotating assy (assume #3 is non-repairable)
o Would need new rotating assy (408?)
o May need to re jet the carb?
• Cost = I&R, ? parts + $ labor. Mike to provide quotes.
Option 2 (basic Sunday driver of the past, not as fast…but more reliable)
• Get it running asap as a good ’20 footer’ (average retail per NADA)
• Swap in van engine/trans, 1986 351w HO/C6 without emissions junk (intake manifold?)
o Comparable power to original engine, lighter/stronger trans
o Make it more like it was stock, but w/electronic ignition
o Inspect for leaks and replace gaskets and pumps as required or prudent
o relocate battery up front, need battery tray and metal work
• Use stock exhaust manifolds if headers won’t fit the R&P steering
• Part out van and misc engine/clevor parts, MSD ignition and Fluid damper, etc
• Cost = I&R, +$800 in parts + $800 in labor? minus sale of van and parts
