Roller Idler arm
Old Dec 14, 2012 | 04:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
what is ORP i must be behind on my abbreviations
Old Dec 14, 2012 | 08:28 PM
Starfury's Avatar
Starfury
Opentracker Racing Products
And yeah, living in a shoebox in Davis. I work in West Sacramento, though.
Old Dec 16, 2012 | 08:57 AM
tx65coupe's Avatar
tx65coupe
I have it too. I think mine looks like James's. Make sure you grease it really good, and it should work fine.
Old Dec 16, 2012 | 02:54 PM
fordmus67tang's Avatar
fordmus67tang
Not too far from me. I'm in Roseville, but also work in Sacramento.
Thanks tx65. Will do..
Old Dec 16, 2012 | 05:52 PM
chockostang's Avatar
chockostang
Very intersting subject here.
The "New" idlers pictured are Moog idlers, or versions of that available at all discount Auto Parts, Same piece, the 65 66 JamesW has--Who Knows??
None of these have the teeth to return to center, all originals had this provision.
Now there are folks that say this is necessary to get the center return on the 65-70, or is this not necessary?
If you folks that run these , NON TEETH, are satisfied good. That makes the teeth thing a item that does not need to be applied.
Need imput here, Necessary, Non Necessary??
http://www.mustangmonthly.com/techar...e/viewall.html
Read the issue about the idler, other posts are rampant.
Dan @ Chockostang
Old Dec 17, 2012 | 01:44 AM
Starfury's Avatar
Starfury
Well, my return-to-center function is definitely decreased since installing the arm. I knew this might be an issue going into the swap, so it doesn't bother me as much.
Old Dec 17, 2012 | 12:46 PM
fordmus67tang
I am fine with losing return to center function. Although, I did think about it... My car originally had PS, but I wanted to go manual. We'll see how she drives when she is on the road again.
Old Dec 17, 2012 | 08:39 PM
Starfury's Avatar
Starfury
I wouldn't say its "lost," just reduced at low steering angles. It's more noticeable at low speeds, although it does require a bit more attention on the freeway to keep the car from following ruts in the road and such.
Old Dec 18, 2012 | 02:15 AM
fordmus67tang
gotcha... how does it feel when you turn at slow speeds?
Old Dec 18, 2012 | 08:34 AM
Starfury's Avatar
Starfury
Actual turning is fine. But if I'm going 20mph and I nudge the wheel 90* (I have a 5-turn box), it's not really apt to return to center. It's fine for me, but I wouldn't do the mod on a car I let my gf drive often.
