Rim Question
Old Mar 20, 2013 | 12:57 PM
jambo's Avatar
jambo
Default Rim Question
Hi Everyone,
I found this on Craigslist, do you think I can fit this without any modification on my 67 fastback (9inch) rear.
http://images.craigslist.org/3L33Jb3...f6a7381023.jpg
Thank you,
Old Mar 20, 2013 | 02:59 PM
120mm's Avatar
120mm
Backspacing?
Old Mar 20, 2013 | 03:20 PM
jambo's Avatar
jambo
I'm not exactly sure about the backspacing. I'm still waiting on the seller to get back to me on that. But bolt pattern 5x114.3. They came off of my 94' toyota 2wd.
Thank you,
Old Mar 20, 2013 | 06:08 PM
jambo's Avatar
jambo
Here is the info
2 wheels are 17x9 with 4 1/2" backspace, the other 2 are 17x10 with 4 1/2" ... I'm not sure about the 17x10 .... what do you guys think, will work without adding wheel spacers?
Thank you
Old Mar 20, 2013 | 10:48 PM
120mm's Avatar
120mm
Here's a tire and rim chart I found online. I cannot guarantee its veracity, but your backspacing sounds about right.
http://www.dodgestang.com/Tire%20Fit...ide%2067-8.pdf
My brain hurts when I try to read that, but it's a good planning figure kind of deal.
Old Mar 20, 2013 | 10:51 PM
1slow67's Avatar
1slow67
ROTM Moderator
17x9 should fit the front, the 17x10 should fit for the rear as well. You shouldn't need a spacer, but if you do it will be something like 1/4" for the fronts.
Best thing to do is see if they will let you test fit them before buying.
Old Mar 21, 2013 | 11:55 AM
jambo's Avatar
jambo
Thank you everyone.
Old Mar 21, 2013 | 06:43 PM
dodgestang's Avatar
dodgestang
Ahh please.....the chart is uber simple to read.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
