Engine backfire on
Old Mar 27, 2013 | 09:22 PM
deathsled's Avatar
deathsled
Default Engine backfire on
my 66 Shelby. It has a Holley 650 double pumper just rebuilt by the shop. This backfire out the side exhaust happened back in early November 2012 then I mothballed the beast. Huge backfire by the way then stall. Restarted after a few tries. The gas seemed choked on the interstate and then stalled comin off the offramp. The gas tank is new but it is old and never used except for a bit of gas at the restoration shop used to start her from time to time. Rust in the tank? New sending unit and sock. Fuel filter? Lodged gasket material from the carburetor rebuild. Car idles along at low rpm okay but get on it and will stall. It's a four speed with toploader and richmond gears.
Suggestions? (Has the cannister type fuel filter) Yes, I know not correct for 66 but engine is a roller rocker while original sits in my closet for a rainy day.
Old Mar 27, 2013 | 10:57 PM
Gun Jam's Avatar
Gun Jam
Im not really sure what question you are asking but I gathered it runs poor under power and it backfired at some point....
Sounds like perhaps the high speed circuit in the carb is plugged up or its a bad fuel pump or it sucked a valve.
1) do compression test on all 8 cylinder is pressure about identical if yes then
2) check fuel pressure and volume place fuel pump "out" line into glass jar crank engine does it quickly fill the jar and splash fuel everywhere? If yes then
3) clean and Rebuild carb.
-Gun
Old Mar 28, 2013 | 02:38 PM
jlg2002's Avatar
jlg2002
Check fuel filter for restriction and replace. If it backfiired through tthe carb as well you probably failed the power valve in the carb.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
