302, .040 or .060 boring?
Old Jun 25, 2013 | 05:01 AM
wonso79's Avatar
wonso79
Question 302, .040 or .060 boring?
Hi, so i picked up a 302 motor and after I disassembled I found out that it's .040 bored and the cylinders have slight ridge/lips on top. Talked to a machine/engine rebuild shop and they said no problem going .060 over. I was thinking of just having it honed to clean it up instead of boring it up to .060.
THOUGHTS????
Old Jun 25, 2013 | 08:20 AM
69thunder's Avatar
69thunder
.060 can have a tendency to run hot and that is pretty much it as far as machining goes I think.
Old Jun 25, 2013 | 10:17 AM
69mach1377's Avatar
69mach1377
What is the clearance between your pistons and cylinder walls and does it meet the recommendation still at .040?
If so, I assume you will use new rings...
How is the top end?
Old Jun 25, 2013 | 04:29 PM
wonso79's Avatar
wonso79
What is the recommendation of the clearance between the pistons and walls?
Old Jun 25, 2013 | 05:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
depends on the type of pistons you are gonna use..as said above i definitely wouldnt go 60 over it try not to go 40 f you can help it
Old Jun 26, 2013 | 08:08 AM
Al Newman's Avatar
Al Newman
A block already .040 over with a top ridge already formed is NOT a candidate for a reliable rebuild. Find another block. The smaller the overbore, the better chance you will have in getting a reliable, cool running engine. All blocks are not the same, and, on occasion, .060 over can be made to work; however, the odds are not in your favor. Casting core shift causes uneven bore thicknesses, which in turn produce hot spots in the thin areas on an overbored block. The thinner walls are prone to flexing, and will break rings rather easily. Lots of downside to too much overbore.
Best,
Al
Old Jun 27, 2013 | 12:18 PM
Diputado's Avatar
Diputado
FWIW....I'm running a moderately-built 289 that's bored .040 over. I've had a hell of a time overcoming overheating problems with it. Engine was built by PO who said it also "ran hot" with him. I did a complete cooling system flush (twice!), and then changed to a FlowKooler water pump, a Champion 4-row aluminum radiator, a 17" flex fan with 289 HiPo fan shroud, and a 160 degree thermostat, and then...and ONLY then...would the temp stay below 190 degrees.
Bottomline...IMHO...302 blocks are just too common and cheap to invest a bunch of hard-earned money and time boring one to 60-over and run the risk of a big headache later.
Old Jun 27, 2013 | 05:37 PM
wonso79's Avatar
wonso79
I think I will hold off on using this block. At least the heads and crank are good that I can use them on a different block.
Galactic
Apr 29, 2019 02:56 PM
bradleyb
Nov 27, 2015 07:50 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jaiidutch
Sep 14, 2015 10:29 AM
