Carb opinions
Old Jul 29, 2013 | 11:11 AM
BabyHuey's Avatar
BabyHuey
Always been with fuel injection, so I have very little carb experience. As much as I would like every last HP out of the engine, driveability and ease of tuning are more important I guess. I'm looking for something easy to work on for starters. Which carb would be a better "starter" carb, the Edelbrock or the QFT?
Old Jul 29, 2013 | 01:33 PM
Gun Jam's Avatar
Gun Jam
I would recommend going with the qft. They are engine tested before they are shipped. Once you set idle mix, float levels and idle rpm im guessing the only thing that's probably going to need tuning much is the primary and secondary main jets. If you get a lean stumble at part throttle cruise when you attempt to accelerate slowly from a normal cruise rpm its likely that the main jets will need to be larger.
Switching jets is easy it takes about 15 min or less.
Getting the QFT dialed in probably will take a bit more patience than the edelbrock but it should not be a "nightmare". QFT techs or mustang forum members should be able to help you out. (Dialing in the QFT should be almost the same as the holley I have so that's what im basing my suggestions off of)
If you get the edelbrock once you have it set up and dialed in you'll just want to switch to the QFT anyhow knowing that chances are there's a noticeable amount of HP left on the table. So save yourself a bunch of money and just get the QFT.
-Gun
Old Jul 29, 2013 | 02:28 PM
67mustang302's Avatar
67mustang302
And buy a tuning book for Holley carbs. You have to know what you're doing to set a carb up right, and there are fewer and fewer places these days that understand how carbs work.
Old Jul 31, 2013 | 01:43 PM
Diputado's Avatar
Diputado
Well...since it's just "opinions" you're interested in...my current setup (Weiand Stealth with a 600 vacuum secondary Holley) to me seems to run pretty good on my 289 with a .508 lift/292 duration cam and headers. It's a dual-plane, but I have had also had good performance on a similar setup running an old single-plane Street Dominator.
Old Jul 31, 2013 | 08:03 PM
BabyHuey's Avatar
BabyHuey
thanks for the reply 'diputado'. I called QFT and im interested, but the carbs come with lilttle tuning instructions. the Edelbrock comes with a manual and a DVD. So i'm back to the 'toss up'. lol thanks again.
Old Jul 31, 2013 | 09:01 PM
Gun Jam's Avatar
Gun Jam
There is lots of tuning info on the QFT site!
-Gun
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
