rack and pinion with headers
Old Aug 6, 2013 | 06:30 PM
MonsterBilly's Avatar
MonsterBilly
Default rack and pinion with headers
I am going to purchase a power rack and Pinion set up for my 66. When I look at the different systems they all say for stock manifold. Will i be able to use a power rack and pinion with my long tube headers?
Old Aug 6, 2013 | 07:21 PM
Coupe's Avatar
Coupe
I would only listen to the manufacturer of the rack you will be buying, you could call em and ask.
Old Aug 7, 2013 | 01:48 PM
69mach1377's Avatar
69mach1377
More than likely you will need to mod the headers with a R&P.
Old Aug 8, 2013 | 07:49 AM
ajzride's Avatar
ajzride
I've got the newest unisteer setup in mine, don't see how it could interfere with any headers, it is way out of the way.
Old Aug 8, 2013 | 01:54 PM
69mach1377's Avatar
69mach1377
How about the shaft to the pinion? The FR pinion joint was right where a header tube should be.
Old Aug 14, 2013 | 12:52 PM
musnicki's Avatar
musnicki
I run a rack and pinion setup in mine and all it did was open up a lot more space. I think that they advertise it to be setup with stock headers to let people know that you can put this system in without having to modify too much more. You should be fine with aftermarket headers. I run a set nice set of large Hookers and they don't even come close to interfering. Removing the clutch Z bar helped as well.
James
Old Aug 14, 2013 | 01:11 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
On my FR setup I tried 2 or 3 different types of headers before I broke down and gave them a call. I wound up speaking with the owner / CEO of the company and asked him which headers to use and he said that they fitted their setup using JBA shorties. So I bought a set and it all fit like a glove.
mtgldr
Feb 3, 2024 09:00 PM
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
junior04
Sep 28, 2015 10:53 AM
