T-10 Trans Problem
Old Dec 28, 2013 | 02:04 PM
BubbaG's Avatar
BubbaG
Default T-10 Trans Problem
I am rebuilding what I believe is a BW Super T10, as it has features of both a T10 and a Super T10. After assembling the main case with the input, counter and main (output) shaft, and then assembling the tail housing and reverse gear to the main case, the reverse idler gear is slightly clashing teeth with first gear.
The mainshaft has .011" endplay as measured by a dial indicator on the rear bearing. With the reverse gear thrust washer on the inside of the main case removed there is .024" between the reverse idler gear and first gear. Assembled with thrust washers on both ends of the reverse idler, the endplay looks about right, although I didn't measure it -- the idler gear in the tail housing just clears the midplate bolt head.
What did I do wrong? Is first gear to far forward?
Any help would be appreciated. Thanks.
Old Dec 28, 2013 | 02:06 PM
BubbaG's Avatar
BubbaG
I believe it is a Super T10 1st design (Ford).
mtgldr
Feb 3, 2024 09:00 PM
warwickbass
Sep 20, 2015 04:51 PM
97SN95GT
Sep 13, 2015 09:45 PM
tramphardrocker
Sep 13, 2015 08:56 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
