best headers
Old Feb 8, 2014 | 11:37 PM
groho's Avatar
groho
I've ran doug thorley on several of my cars, running tri-y's, and love em. So far, no issues, but I haven't put in the R&P yet. Also running a C4. These are very good headers and very well made. Have never,....never...had an exhaust leak.
Old Feb 10, 2014 | 07:30 AM
Al Newman's Avatar
Al Newman
FINALLY11111 I knew that sooner or later, I would find someone running headers who has not experienced a leak. You are to be congratulated.
Best,
Al
Old Feb 10, 2014 | 05:17 PM
67mustang302's Avatar
67mustang302
Good headers have thick flanges, and if you use good gaskets they won't leak at the heads. I like ball/socket flanges like on JBA etc, which is what OEM uses. It's basically a compression fitting that uses no gasket, they only leak if they're too loose or damaged.
Old Mar 9, 2014 | 10:13 PM
1966fastbach's Avatar
1966fastbach
FPA headers are the Best. Hands down.
Old Mar 15, 2014 | 06:06 AM
dragman72's Avatar
dragman72
If I switch headers how much will I have to modify the rest of the exhaust?
Old Feb 13, 2015 | 04:44 PM
66_13_Stangs's Avatar
66_13_Stangs
I have a 66 289, T5, Hydraulic Clutch, stock heads, Cobra 4bbl intake, Holley 650 HP Street Mechanical secondary's, 3.55 rears and going to put in a rack and pinion not sure if it will power steering yet, my Hydraulic cam has a Cam Lift .288 Int/Exh. Valve Lift .460 int/exh. Advanced Duration 288 Int/exh. and .050 duration 218 Int/exh. I have lowered the car by about 1 to 1.5" in front and love low end torque but want to be able to have some power at top end. I have a 13 GT for top end fun. I would like to know the best header for my application. Brand style (Shorties, Tri-Y or LT).
Old Feb 13, 2015 | 07:53 PM
barnett468's Avatar
barnett468
these are the best for yoir app and are killer headers for the money . . super thick 14 gauge tubes and 3/8" thick flange.
you can use remflex gaskets with them . . paper gaskets suck.
http://www.summitracing.com/parts/he.../model/mustang
Old Feb 13, 2015 | 07:58 PM
barnett468's Avatar
barnett468
Originally Posted by dragman72
the shorties look like they would have the best clearences but I don't wanna give up HP either. need someone with experience to chime in
these are the best all around for engines with around 300 hp and less and are killer headers for the money . . super thick 14 gauge tubes and 3/8" thick flange.
Old Feb 13, 2015 | 11:34 PM
WestCoastShelby's Avatar
WestCoastShelby
Banned
Patriot Tri-Y's are great bang for the buck $327 (ceramic coated) or uncoated $216, However the fit on both is hit or miss, like flipping a coin, out of the box.
Uncoated will heat up the engine bay considerably more than ceramic coated, but if you want to customize the fit (clearance certain areas) that is the way to go them mail them off to get ceramic coated (JetHot, etc) after your done clearancing them.
Don't forget the drop bracket for PS cylinder if you run PS.
Old Feb 15, 2015 | 04:09 PM
66_13_Stangs
Thanks I will check them out
