Ignition cylinder
Old Feb 7, 2014 | 09:22 AM
ProblemHouston's Avatar
ProblemHouston
Default Ignition cylinder
So the girlfriend was pulling in the 65 fastback about a week ago while I was inside working on our remodel and she has in her hand the ignitioin key cylinder still attached to the key. She says "I turned it off and it went past the point to turn the car off and I pulled it out". When I went outside to look at it the "ALT" light and accessories were still on. I tried to put it back in but I couldn't get it. I had to just disconnect the battery so it didn't drain. I have tried a few times since then to get it in but have failed. Anyone have any advise on how to get this back in?
Old Feb 7, 2014 | 09:58 AM
69mach1377's Avatar
69mach1377
Is there a small hole on the face that will retract the gripping mechanism? If so, stick a straightened paper clip into it.
Free bump
Old Feb 7, 2014 | 10:51 AM
ProblemHouston
I just watched a video that was showing that little hole and how it releases it from the switch. I am not at home now but will check it out and post a picture of it when I get home.
Old Feb 11, 2014 | 06:31 PM
69mach1377's Avatar
69mach1377
Fix it?
Old Feb 12, 2014 | 09:57 AM
ProblemHouston
Originally Posted by 69mach1377
Fix it?
Yes sir, thanks to you! Got everything aligned with a paperclip in that small hole and she popped right into place.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
bradleyb
Nov 27, 2015 07:50 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
