Hopping up a 170
I was just wondering how many horses could i get out of a 170, and whats the best cam, head, and intake for it, and where to get them from. Thank you
around 50 hp total, if you want to accelerate quick change your gears to 350's.
Originally Posted by barnett468
(Post 8366707)
If you are intent on hopping up an I6 Ford engine, go to the 200 CID unit. The 170 does not support the crankshaft nearly as well as the 200. My advice, however, is to get a V8 - more horses- less hassle - cheaper.
Best, Al |
Originally Posted by Jeff272
(Post 8366734)
50 hp, i thought they came with 105 hp?
The 170 has 4 bearings and is not recommend to be modded. The 200 (7 bearings) or 289 on the other hand can be modded much easier. If you want to make it accelerate faster switching the gears to 4.10s or something similar will help to do so. Then switch your headers and get dual exhaust for sound. Edelbrock makes the best intake manifolds by far. I wouldn't recommend internally modding a 170 though. I am not a pro so If I have made any mistakes please do correct me. Thanks
Originally Posted by jonahdeich
(Post 8367475)
Check out www.fordsix.com and www.classicinlines.com as they have a lot of info. You will want to go to the 200ci if you want any kind of real power. If you do go that way then there are some pretty good power gains to be had.
(Post 8367475)
Best, Al |
