T5 question
Old Apr 16, 2014 | 09:50 PM
Williams1370's Avatar
Williams1370
Default T5 question
Hi, I jumped into the T5 conversion idea head first, and now that I'm learning more, I have some questions. I have a 65 mustang with a 1972 302 block. I just purchase a new WC t5 with a s10 tailpiece. I was told this was the way to go, especially if I wanted to use a hydraulic clutch. I have read this is pretty common, and the shifter location should be fine. The input shaft is a 025 from a 1985-1992 mustang. I went out an bought a 1994 bellhousing, which after doing a little research, I have learned will probably not work, because the input shafts got longer in 1994. Is this correct? Do I need a bellhousing from 1993 and under?
Old Apr 17, 2014 | 12:03 AM
guitarman376's Avatar
guitarman376
Yes you will need one. I happen to have one for sale. Pm me if interested.
Old Apr 17, 2014 | 05:24 AM
Williams1370
I think since this was my first lost, I don't have PM capabilities yet. Can you send me the info about the bellhousing to my email address? Williams1370@yahoo.com. Also, the tailpiece from the s10 should work, correct?
Old Apr 18, 2014 | 10:05 AM
69mach1377's Avatar
69mach1377
Not sure why an S10 tail is the way to go...where did you get that info?
Old Apr 29, 2014 | 07:06 PM
Stangatic's Avatar
Stangatic
No s10 POS here
Old May 7, 2014 | 10:31 AM
69mach1377's Avatar
69mach1377
https://mustangforums.com/forum/part...lus-parts.html
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
