Distributor installation
Old Dec 21, 2003 | 10:46 PM
Utah 66's Avatar
Utah 66
Default Distributor installation
I can find TDC on #1 but I am not sure where the rotor should be pointing. Does anyone have any advice on the right way to put my dizzy back in? I know once I get it close I can time it later but I am not sure where to put it to get it close enough.</P>
Thanks</P>
Chris</P>
Old Dec 21, 2003 | 11:43 PM
1966 Mustang15's Avatar
1966 Mustang15
The way you do it is after you have the distributor in set the cap on like it is supposed to go have it on tdc get the number one plug wire and put it on the on the stud that that rotor is pointing at.
Old Dec 22, 2003 | 12:05 AM
WyDoPn's Avatar
WyDoPn
I thikn 66 hit it right on the head to get u in the general area
1966 Mustang15
I saw that you told that other guy where his mustang was made and all that stuff can you tell me some stuff about mine because i dont know where to look up the numbers at. My vin is 6f07t351965 Thanks Corey
Old Dec 22, 2003 | 12:08 AM
Utah 66's Avatar
Utah 66
Ok, so it does not matter which way the dist points when I put it in, it is that the #1 wire is where the rotor points when #1 piston is at TDC.</P>
If that is what you mean I understand, Thank you.</P>
Old Dec 22, 2003 | 12:11 AM
1966 Mustang15
Your right. If it does not run it is probably 180 out so do what i said and if it wont crank pull out the dist and turn the rotor 180 around. or you can put it on tdc and stick a screwdriver in the number 1 piston hole and if the piston is all the way up do what i said earlier
Old Dec 22, 2003 | 12:16 AM
Utah 66's Avatar
Utah 66
<TABLE>
<T>
<TR>
<TD>
Corey, Here is what I have on hand, I can find more if you need it. </P>
</P>
Code</P></TD>
<TD></TD>
<TD>
</P>
Assembly plant</P></TD></TR>
<TR>
<TD>F</TD>
<TD></TD>
<TD>Dearborn, Michigan</TD></TR></T></TABLE>
<TABLE>
<T>
<TR>
<TD>Body Code</TD>
<TD></TD>
<TD>Body Style</TD></TR>
<TR>
<TD>07</TD>
<TD></TD>
<TD>Hardtop</TD></TR></T></TABLE>
<CENTER>
<FONT size=+2>Engine Codes</FONT></P></CENTER>
<CENTER>
CID = Cubic Inch displacement, V8 = 8 cylinder, I6 = 6 cylinder, V = induction venturi (4V would be a 4 barrel carburetor)</P></CENTER>
<CENTER>
<TABLE>
<T>
<TR>
<TD>Engine Code</TD>
<TD></TD>
<TD>Engine Type</TD></TR>
<TR>
<TD>A</TD>
<TD></TD>
<TD>V8 289 CID 4V</TD></TR>
<TR>
<TD>C</TD>
<TD></TD>
<TD>V8 289 CID 2V</TD></TR>
<TR>
<TD>K</TD>
<TD></TD>
<TD>V8 289 CID 4V High Performance</TD></TR>
<TR>
<TD>T</TD>
<TD></TD>
<TD>I6 200 CID 1V</TD></TR></T></TABLE></CENTER>
Old Dec 22, 2003 | 12:17 AM
Utah 66's Avatar
Utah 66
that is assuming you have a 66
Old Dec 22, 2003 | 12:18 AM
1966 Mustang15
Thanks alot. Mine is a 66<edited><editID>1966 Mustang15</editID><editDate>37976.9298726852</editDate></edited>
Utah 66's Avatar
Utah 66
firing orded?</P>
I know the order but does the rotor spin CW or CCW?</P>
