Upper Control Arm Lube
Old Sep 1, 2014 | 03:01 PM
unit91's Avatar
unit91
Angry Upper Control Arm Lube
I've been using a hand-held grease gun all my life (I'm 65) but now I can't get the upper control arms in my 68 Stang to accept grease. I've removed and inspected all 4 zerks and they are functioning properly and are not clogged up. Any ideas?
Old Sep 1, 2014 | 03:07 PM
67mustang302's Avatar
67mustang302
Is the gun rock hard when you try to add grease? If the joint is saturated, then there will be too much pressure for the gun to pump against. Especially with newer ball joints that seal a lot better.
Old Sep 1, 2014 | 04:38 PM
unit91's Avatar
unit91
The gun is rock hard, and the grease squirts out around the zerks instead of going in. I had this done at the local Firestone last year and the guy said he had problems getting grease to go into these zerks but finally did get some to go in (supposedly). Control arms aren't new - they have some age on them.
Old Sep 1, 2014 | 07:10 PM
67mustang302
I've had the same issue, with a newer gun that seals on the zerk really well, and especially newer arms/joints. There's so much pressure inside the fluid cavity in the joint you can't push any more in. If that happens it means the joint is full of grease, and hasn't lost much over time.
Old Sep 1, 2014 | 07:15 PM
unit91's Avatar
unit91
roger that...........thanks!
Old Sep 1, 2014 | 08:08 PM
67mustang302
Also, don't try to force a little extra in either, some guns can get their locking mechanism jammed on the zerk that way. Makes it a real pia to get it off.
Old Sep 1, 2014 | 08:31 PM
barnett468's Avatar
barnett468
[QUOTE=unit91;8423727]The gun is rock hard, and the grease squirts out around the zerks instead of going in.[/quoote]a good gun will leak little to nothing around the fitting when it is full.
as ,entioned, your arms are likely full. stop greasing them, lol.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
