shock tower crack
Old Mar 13, 2015 | 10:29 AM
Stoke's Avatar
Stoke
Default shock tower crack
I was cleaning up the fender well area of my 1970 mustang and found this crack to the shock tower area. It is in the side of the shock tower that faces the radiator support on the passenger side. My question is, is this something that I can just put a weld on to close or do I need to replace the shock tower component completely? I don't know what caused the crack but it doesn't appear to be in an area that would be exposed to a great deal of movement or force.
Old Mar 13, 2015 | 04:32 PM
Shoelessjoe75's Avatar
Shoelessjoe75
Yes you can weld it up. Clean weld area up really good first. Drill small holes at the ends of the cracks, that will stop the crack from spreading any more and then weld it up.
Old Mar 13, 2015 | 08:36 PM
Stoke's Avatar
Stoke
Thank you for your reply. I was thinking that but just wanted to get a 2nd opinion.
Old Mar 14, 2015 | 12:34 PM
69mach1377's Avatar
69mach1377
IIRC there is also a recommended shock tower reinforcement weld of some sort.
Old Mar 14, 2015 | 03:18 PM
67mustang302's Avatar
67mustang302
You can get paperback versions of the Boss chassis modification manual from the racing days in the late 60's and early 70's, has quite a few reinforcing tips in it.
http://www.cjponyparts.com/book-boss...ation/p/BKBCM/
Some of the suspension stuff has been outmoded to a degree by technology, but it has some good tips for chassis tweaks.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
