Brakes going mushy...what could be the cause?
Old Feb 29, 2016 | 09:24 AM
snafu7x7's Avatar
snafu7x7
Originally Posted by Mustangdemon67
when installing a new master it needs to bench bled before the install. sadly many shops dont do this and you ll never get all the air out of the system no matter how much bleeding you do. this may be the problem. usually when a booster goes bad you ll hear hissing but boosters are just brake assist so a little lady can stop as hard as a line backer.
Hey demon, thanks for the reply, I'm hoping to troubleshoot this ahead of time so I can order any parts etc and give them specific instructions because I've already had it into this shop 3 times for the brakes and I'm getting fed up with it.
I do hear a hissing of sorts (like the sound of air leaking from a tire) when the engine is running coming from where the vacuum hose attaches to the booster (see photo I attached). If I put my finger over that little nipple you can feel the suction like when you put your hand over the end of a vacuum cleaner hose. That's not what you mean is it?
Also to answer you other question, it has discs in the front and drums in the rear. I don't think they adjusted anything on the brakes themselves when they replaced the master cylinder. And it does brake fine, you just really have to come on to it hard to make it stop.
Old Feb 29, 2016 | 11:43 AM
Mustangdemon67's Avatar
Mustangdemon67
Seems like you have a vacuum leak there. Plug that hole with a vacuum cap and your brake assist should return to normal. That line should be sealed, shouldn't hear any hissing.
Old Feb 29, 2016 | 12:44 PM
snafu7x7's Avatar
snafu7x7
Wow amazing that such a small thing could be causing that problem! I jury rigged it a wire screw on connector and a little duct tape and 'presto' suddenly I have power brakes again! Thanks a bundle man, you saved me a lot of hassle and probably money. Looks they sell kits of those caps on amazon with various sizes so I'll get one of those and do the job right, thanks again!
Old Mar 1, 2016 | 08:59 AM
bop11's Avatar
bop11
If you have an auto transmission, there should be a vacuum hose from that nipple to the transmission The transmission pressure is vacuum controlled from this line. With a manual transmission there should be a cap on that nipple.
cxs4887
Jul 30, 2019 09:16 PM
Evansmotorsports
Jan 16, 2016 02:28 AM
Nando.
Jan 12, 2016 01:08 AM
Detroit Steel
Mustang Videos
Jan 5, 2016 10:04 AM
Suro Kim
Jan 3, 2016 06:13 PM
