Cold Air
Old Oct 24, 2005 | 10:05 PM
  #21
dodgestang's Avatar
dodgestang
Default RE: Cold Air
Here's my solution:
Also gives me enough room to put my strip dominator intake on.....go figure
Add to a flow through lid or fab up a box to seal against the underside and you are good to go [8D]
Old Oct 25, 2005 | 02:18 AM
  #22
fast66's Avatar
fast66
Try this Link,
http://aussiev8.com.au/images/articles/1/engine-bay.jpg
This is from an Aussie Commodore (GM) from about 1984. The plate shown acts as a scoop to pick cold air up from the grill, and force it into the carby. it has a seal arond the top edge to seal against the Hood inner. You need to use an open type aircleaner (ie HIPO).
Old Oct 25, 2005 | 03:16 AM
  #23
waxyourboard's Avatar
waxyourboard
Has anyone thought of a hood scoop yet? Maybe something like the shaker hood scoop... Plus i think one of the problems hooking a CAI directly up to the carb is the sharp 90 degree turn it has to take to get into the carb
Old Oct 25, 2005 | 03:28 AM
  #24
Fastback Guy's Avatar
Fastback Guy
I have the feeling that someone is going to work the bugs out of all this! I can't wait to see the results.[sm=goodidea.gif]
Old Oct 25, 2005 | 07:51 AM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: fast66
Try this Link,
Now, there is a great idea. But, expensive and impractical because it would have to be removed to work on the car. You also have to somehow alter the hood to fit it in there it seems. Otherwise, how does the air get in?
Old Oct 25, 2005 | 08:27 AM
  #26
tylerdru's Avatar
tylerdru
We cant sit here and keep talking! im gonna get some cardboard and make a "prototype". What do you do if you have the design but cant fabricate it? Sell your idea?
Old Oct 25, 2005 | 08:35 AM
  #27
Soaring's Avatar
Soaring
I ♥ Acer
You need to build a real prototype that actually works that is unlike any other, then apply for a patent. Big bucks could be made if you can get someone to actually mass produce them.
Old Oct 25, 2005 | 09:31 AM
  #28
gta289's Avatar
gta289
i have heard that turn signal hoods on 67-68 have the same cooling effects as the 03-04 cobras with the same reverse type vents. It has been debated for years that, the turn signal, do not have function, but just recently have heard from numerous people that that they do have function, and do help direct heat out of the engine. I dont know im just rambeling on again
Old Oct 25, 2005 | 11:07 AM
  #29
jrrhd73must's Avatar
jrrhd73must
The shaker hood (69-70) or the operational NASA hood (71-73) did exactly that cold air. I have a F250 Diesel that is my daily driver, and I built a homade cold air intake for it. For the mustangs I have seen something similar to the blue air cleaner posted only in black with less restrictive openings.
Old Oct 25, 2005 | 04:18 PM
  #30
garywwelch's Avatar
garywwelch
Help me understand why the cold air is so important? Some articles I have read say the engines wants warn sticky air. I assume this means is uses less fuel this way.
Thanks
Gary
66 Fastnback
