Seized front drum
Old Jun 12, 2016 | 02:27 PM
ewgoforth's Avatar
ewgoforth
Default Seized front drum
The right front drum is seized on my 65. Any way to take off other than a hammer?
Old Jun 12, 2016 | 03:52 PM
barstowpo's Avatar
barstowpo
Try backing off the adjusters through the backing plate with a brake spoon or screwdriver.
Old Jun 12, 2016 | 04:09 PM
Mustangdemon67's Avatar
Mustangdemon67
Then hit it with a hammer
Hit the front though, not the lip or it could break
Old Jun 12, 2016 | 05:12 PM
Chromeshadow's Avatar
Chromeshadow
Some of the aftermarket drums have 2 threaded holes in them, these are used to run screws into to back out the drum. I don't think the factory drums had them.
Old Jun 13, 2016 | 02:54 PM
bop11's Avatar
bop11
Are you sure it is the drum and not the hub bearings that are seized? You just can't remove the drum, you must take the cotter pin out of the spindle nut then remove the nut and the bearings come off with the drum. It is different than the back drums which are held on by the lug nuts.
Old Jun 13, 2016 | 03:01 PM
barstowpo's Avatar
barstowpo
bop11 makes a good point. Most of my drum brake cars have had the drums replaced so many times this is no longer true. Original front drums were anchored to the hubs bu the studs.
Old Jun 14, 2016 | 08:27 PM
ewgoforth's Avatar
ewgoforth
This was the key thing that I was missing. I didn't realize this until I did a bit of research on the internet. I backed off the adjuster to make the drum easier to get back on after I cleaned it out. It was quite rusty.
-Eric
Old Jun 14, 2016 | 09:07 PM
barstowpo's Avatar
barstowpo
This stuff gets easier. Glad it worked out.
squishbang
Dec 5, 2016 06:03 PM
crazyhorse
Nov 23, 2016 03:01 AM
kennyb310
May 20, 2016 03:37 PM
Silverblade
May 17, 2016 08:35 AM
jerryboy
Mar 18, 2016 06:56 PM
