289 Bore? How Much?
Old Oct 25, 2005 | 11:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 289 Bore? How Much?
i had my cleveland block sleeved i think it was around 70 a hole i only needed one but sleeving makes the block stronger
[IMG]local://upfiles/23144/860D32C6B1084A3BB052033C36828F9A.jpg[/IMG]
[IMG]local://upfiles/23144/50E9D4A36F984AEA8CAD50B620FD5BF8.jpg[/IMG]
[IMG]local://upfiles/23144/FEA135855E544ADB9EB63046E602C354.jpg[/IMG]
[IMG]local://upfiles/23144/2FDDF7946B56458B8C5D3D07CA80A494.jpg[/IMG]
Old Oct 25, 2005 | 11:43 PM
garywwelch's Avatar
garywwelch
OK now we are into a whole new subject. Drop a 5.0 in? That sound interesting, how difficult is it to match up to the existing 4c?
Old Oct 26, 2005 | 12:08 AM
LS2_GTO's Avatar
LS2_GTO
Most people here agree, as do I. My 289 was bored .030 over and that is just right for that engine.... I definately would not go .060. You would get more bang for your buck to get a good 289 block from a junk yard and work that. And personally I would keep a 289 in it (sweet engine) and possibly a 302, but DO NOT put a 5.0 in that thing.
My .02 cents.
Old Oct 26, 2005 | 09:58 PM
hutchamatic's Avatar
hutchamatic
Bolts right up. A 5.0 is a 302, GEESE. The only thing you would have to do is change timing covers from your 289, add the fuel pump eccentric and get the correct flywheel which is availble for around $60 bucks. Also a balancer is avail for your 3 bolt crank pulley. It is one of the best things you could do for your car. Better power, more mileage, durable. And once it is done no one will know if it is a 289 or a 302 (5.0)
Old Oct 27, 2005 | 09:26 AM
Soaring's Avatar
Soaring
I ♥ Acer
There were no numbers matching early Mustangs. The 302 will bolt right up, as the block is virtually the same. The main difference is internal. If you can find a 289 that hasn't been bored yet, that would be a little less trouble than a 302, but not much. Either way you go, that block is toast as it has already been bored to .40 over......that is unless you get it sleeved as mentioned. I have always been leary of sleeved engines though. Just my opinion.
Old Oct 27, 2005 | 11:04 AM
hutchamatic
The 84 up 302's were 50oz balance and the the prvious was 28.8oz.
Old Oct 27, 2005 | 12:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's true, but if you put the entire engine in, it will already have the correct balancer on it. At least I presume so.
Old Oct 27, 2005 | 11:13 PM
garywwelch's Avatar
garywwelch
OK, here is the update on the latest on the shot 289. I found a complete 302 with only 7K miles on it after an $1800 rebuild. It was built and placed in a 68 that was totalled after a rear end acident. He bought the car back from the insurance company 2 yrs ago and parted out the salvage. HE held on to the engine with plans to put it in another car, but later changed his mind. He did not want to sell it, but was willing to let me take it. He is a friend on mine from Lubbock and is letting it go for $1,100.00. It has an Edelbrock intake and carb, mild cam. He has started it every month to keep it lubed. I have total faith in him as he is a very big mustang guy. You have probably seen one of his car in an article in Mustang Monthly and other auto mags. It has been published 8 times in various car mags. It is the only one Ford ever produced - It's Pink! Yes I said pink. He also owns a couple Pace cars and one is signed by Mr. Shelby himsself.
I plan to pick it up this weekend.
Old Oct 27, 2005 | 11:25 PM
tylerdru's Avatar
tylerdru
Nice find. wow you are going all out. Ahh the playboy pink car!
Old Oct 29, 2005 | 02:18 PM
hutchamatic
That sounds a little expensive.
