Help with engine ID?
Old Jun 30, 2017 | 02:26 PM
Bones69's Avatar
Bones69
Default Help with engine ID?
Here are a couple photos of the engine in a 69 fastback that my wife and I inherited. Have looked all over the block, but for the life of me can't seem to locate any stamping or numbers of any sort. Any help would be greatly appreciated. Thanks
Tony
Attached Thumbnails Help with engine ID?-20170630_121118.jpg   Help with engine ID?-20170630_121141.jpg   Help with engine ID?-20170630_121156.jpg   Help with engine ID?-20170630_121221.jpg
Old Jun 30, 2017 | 04:18 PM
Starfury's Avatar
Starfury
Definitely a small block ford, so 289/302/351W.
Look at the small area on the block directly behind the intake. There might be a VIN stamping on the flat spot in that area (which you'd have to wipe clean to see).
What's your car VIN? If the two stampings match, then the engine is original and would match the engine VIN code.
Old Jun 30, 2017 | 04:30 PM
Bones69's Avatar
Bones69
Thanks Star, I'll see what I can find after camping for the 4th, appreciate your quick response! Stay tuned
Old Jul 1, 2017 | 12:40 PM
Gun Jam's Avatar
Gun Jam
arent the block codes hidden behind the starter motor?
Old Jul 1, 2017 | 08:39 PM
Starfury's Avatar
Starfury
Casting numbers are, but the VIN stamping is in a visible area, so easier to check if it's there
Old Jul 6, 2017 | 08:21 PM
Bones69's Avatar
Bones69
Nothing behind the manifold, not much room there where the tranny bolts up, you think behind the starter motor, as maybe it's not the original engine?
Old Jul 6, 2017 | 09:31 PM
Starfury's Avatar
Starfury
Casting numbers hidden by the starter will give a rough idea of what it is.
What's your VIN? We can at least establish what's supposed to be in the car.
Old Jul 12, 2017 | 02:56 PM
Bones69's Avatar
Bones69
The VIN #: 9F02M120813. My wife was able to track down the 2nd owner, he seems to think it's not the original motor, maybe a 351W though...... thoughts?
