CLutch clutch clutch
Old Aug 26, 2017 | 12:37 AM
MonsterBilly's Avatar
MonsterBilly
Default CLutch clutch clutch
So i have a centerforce dual friction clutch. I notice under very hard accelerating, over 5500 rpms, if i try to **** fast, the clutch pedal does not want to return all the way up from the floor.
After the rpms decrease, the pedal comes back up.
Is this a sign that it is worn out?
at low rpms, it is fine.
the clutch is about 9 years old and has about 20k very hard miles on it.
Old Aug 26, 2017 | 12:56 AM
Gun Jam's Avatar
Gun Jam
Internal or external slave?
Cable?
That sounds more like a binding issue.
Check for play and check for anything that might be suspect of a bind
Old Aug 26, 2017 | 08:40 AM
Starfury's Avatar
Starfury
Do you still have the under-dash clutch assist spring installed? If so, remove it.
Old Aug 27, 2017 | 06:12 PM
guitarman376's Avatar
guitarman376
Other than what's been mentioned...is there any chance the input shaft has been twisted? If your sig is right you have a t5, so it's possible...
Old Aug 27, 2017 | 10:35 PM
MonsterBilly
yes, i do have a T5. it is very new and was custom built for my set up.
I have an extrenal slave. i will take a look for binding but there is not really mutch to bind.
i did remove the under dash assist spring when i installed the hydo clutch.
if i take it apart, i want to have a clutch on hand to install since mine is 10 years old and has had a ton of use. please recommend, i am listening.
i have really liked the dual friction but it is a little spendy these days
Old Aug 27, 2017 | 10:45 PM
Gun Jam's Avatar
Gun Jam
well talk to modern driveline.
Im running their 10.5" full kevlar clutch. It has great holding power and is much smoother engaging than the king cobra I use to run.
Tell them what you are doing your hp requirements and their thoughts on the kevalr system in your case.
http://www.moderndriveline.com/
