Horn unit hot to touch
Old May 13, 2018 | 06:30 AM
snafu7x7's Avatar
snafu7x7
Default Horn unit hot to touch
Came out in the garage this morning and smelled that electrical burning smell, popped the hood and sniffed around, and moved my hand around until I identified the heat source. The left horn unit is too hot to touch, the right one is cool. I disconnected it immediately but is there possibly anything else going wrong or just a faulty unit. Yesterday when moving the car the horn came on when it bumped the threshold into the garage (just the vibration triggered it). Very odd.
Old May 13, 2018 | 11:28 AM
barnett468's Avatar
barnett468
does the horn that is left still work.
it also sounds like there is a problem with your horn ring. this is not uncommon. i would take it off and check out the pieces. the 3 prong plastic horn retainer sometimes gets a tab broken off which can cause the horn to go off over bumps etc.
Old May 14, 2018 | 06:29 AM
snafu7x7's Avatar
snafu7x7
Yeah the other one doesn't seem to work at all, I'm going to take your advice and replace the horn ring while replacing the horn unit
Old May 14, 2018 | 07:43 AM
GT Nate's Avatar
GT Nate
check the horn relay, could be an open circuit going to that horn...just building up heat.
Old May 14, 2018 | 09:52 AM
barnett468's Avatar
barnett468
an open circuit would not build up heat.
Old May 14, 2018 | 09:54 AM
barnett468's Avatar
barnett468
i didn't say to replace anything. find the problem first. also, disconnect the battery when removing and installing the chrome horn ring.
Old May 21, 2018 | 04:03 PM
bop11's Avatar
bop11
Did you replace the steering wheel? On some wheels, you need to remove a piece of the horn internal ring. The horn in these is fed from the horn ring, it is not grounded by the horn ring. The horn goes to ground the power is fed from the ring.
Old May 21, 2018 | 05:01 PM
GT Nate's Avatar
GT Nate
darn it you're right, my bad. Closed... something seems to be acting like a resistor.
artctr
Oct 23, 2015 02:04 PM
mustang0672
Jan 7, 2013 09:34 AM
Will93lx2.3hachback
4 Cylinder NA and Turbo
Oct 17, 2006 11:29 PM
badazz68stang
Mar 11, 2006 09:41 PM
