Engine rebuild
Old Oct 29, 2005 | 12:00 PM
66stilinprimr's Avatar
66stilinprimr
Default Engine rebuild
I have decided to rebuild my 200 I6...So I need a lot of parts and a lot of time because I am going to replace everything...Any ideas on what parts to use or maybe some machine work?
Old Oct 29, 2005 | 03:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine rebuild
These guys probably have answers to most of your questions. www.fordsix.com Basically though, you need to tear the engine completely down, and take the block in to have it cleaned and re-bored. Then the head needs to be overhauled. Then the crank needs to be either replaced or ground. Depending on the condition of the rods and pistons, one or all of them may have to be replaced. New rod bearings,and new rings, of course. New oil pump. Possibly a new distributor and plug wires with new plugs. Overhaul the carb. All new gaskets. If you want to heat it up a bit, follow the guides of the fordsix site.
Old Oct 31, 2005 | 11:21 AM
0zenon0's Avatar
0zenon0
Soaring can you reccomend a good similar site for V8s (C code specifically), I am sure there are plenty. Thanks
Old Oct 31, 2005 | 11:25 AM
gta289's Avatar
gta289
ORIGINAL: Soaring
ive heard of some company in austraillia that makes a intake for a 4 barrel on a six cylinder! im not sure where i heard it but man that would be cool. summit racing also makes a 6 cyl header
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Mikett
Sep 12, 2015 10:52 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
