Heater hoses
Old Jan 23, 2020 | 09:05 PM
sg47619's Avatar
sg47619
Default Heater hoses
Ok I’ve lost it. Putting heater hoses back on a 289 65 Mustang I’ve slept since I took them off I thank the top heater hose goes to the water pump and the lower goes to the manifold. Right or Wrong. Thanks
Old Jan 23, 2020 | 10:25 PM
imp's Avatar
imp
World of hurt! Connected backwards, the heater will COOL instead of heat the car!
imp's Avatar
imp
Old Jan 24, 2020 | 03:35 PM
Gun Jam's Avatar
Gun Jam
By that I think he means it won't matter. One should be a bit longer right? Place that one on the water pump
Old Jan 26, 2020 | 06:22 PM
sg47619's Avatar
sg47619
Still can’t get any heat in the car.
Old Jan 26, 2020 | 06:59 PM
Gun Jam's Avatar
Gun Jam
Its likley because the hose is pinched behind the firewall...right behind the heater box. This is 95% possibility. If you are sure that its not pinched behind the heater box (that means you mostly removed the heater box and physically inspected each hose for kinks) Then a hose is plugged, a fitting (water pump or intake) is plugged, or heater core is plugged.
Easy peasy to hunt down.
Old Jan 26, 2020 | 07:02 PM
sg47619's Avatar
sg47619
I checked the hose temps today. Block was 180. Top heater hose was 115 bottom hose was 140
Old Jan 28, 2020 | 12:11 AM
Gun Jam's Avatar
Gun Jam
another test would be to remove both hoses and see if you can easily blow threw then or hold one up higher and water should pour out the lower hose.
If you're sure they arent blocked then we can move on to the heater box selectors. is the flap that controls heat flow through the box opening and closing (should connect to "Temp" lever)
nassaubayman
Jun 7, 2010 08:40 AM
XXC
4 Cylinder NA and Turbo
May 2, 2010 05:23 PM
cfd2bc
Nov 6, 2009 04:17 PM
JChase
Apr 8, 2007 03:52 PM
cool66
Apr 8, 2004 11:58 PM
