engine rebuild- 6cyl
Old Nov 13, 2005 | 04:18 PM
my 67's Avatar
my 67
Default engine rebuild- 6cyl
Will be going through my engine this winter. got from original owner and she drove it so little that the engine was never broken in.
Plugs 2-5 get caked with crap but 1&6 are pretty good. What do I need to look for and fix, I know rings will most likely need work or repalcing. Are there items out there to upgade to for our new crappy gas. I live in Wisconsin and we have to have 10% ethenol in our gas. thanks in advance for you input.
Old Nov 13, 2005 | 04:36 PM
gta289's Avatar
gta289
Default RE: engine rebuild- 6cyl
just do a oil change,and run it around the block to get it up to running temp, than change it again to insure its clean, as for the ring and the cylinder walls, i dont thing thats a cause for concern, mainly because if the engine wasnt broke in thats not a bad thing, its if its not broken in and you go racing in it than well have problems but its a I6 i wouldnt worry about that. Normal drive wont hurt the motor at all. Change the spark plugs with new ones, and just for kicks up the octane to a 91 just for this once, get all the old burned off, and than go back to reg. If the spark plugs are gunking up, i would check to make sure the carb is still good, and that its not burning to rich or to lean, (remember its better to burn to rich than to lean) change the plug wires, aintifreeze, test the thermostat, basically give it a full tune up. There is no need to tear down a good engine, you must see if its good first, and if this fixes the problem, than i would than suggest pulling the motor, and refurbishing it (ie: repainting it, changings gaskets etc) but dont jump to conclusions that the motors shot, do all the things i listed and im pretty sure itll fix the problem. Take your carb if you dont know how to work on them, to a good carb guy, and let him know what the plugs look like, if the car has heistation problems etc, this way he can do adjustments, and fix as nessasary.
oh and please change the fuel pump, filter,rubber gaskets that dry rotted, and take the old gas out of the tank first!! VIa the drain plug in the bottom. when it comes to bad signs of engine distress, look at the plugs really good, do they look burnt? how does the oil smell? let me know???
Old Nov 13, 2005 | 05:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Good advice Joe. The best thing you could do with that car is to drive it. Change all the fluids, plugs etc., then take it for a 500 mile trip one way. It just needs to be driven as it was designed to do.
Old Nov 17, 2005 | 07:13 PM
my 67's Avatar
my 67
didn't drive it that far, but it is in storage now. did most things Joe mentioned. Any other advice??
Old Nov 17, 2005 | 07:27 PM
my 67's Avatar
my 67
Changed plugs, wires, oil, points the day after I bought it in June. Also did some adjusting to carb. It still ran a little rough, and would kill after short stops to the store. (only sat less than 15 min.) It does blow blue smoke on start up, but not a lot. Plugs didn't look burnt just, caked with carbon(I think). It was black gunk. Cleaned them twice during the summer. What about the valve? seats, could they be bad? A friend says they might be. Car is in storage now with a tank full of premium in it, do I need to drain it to get to the pump? Where is it?
Old Nov 17, 2005 | 07:35 PM
my 67's Avatar
my 67
could i just rebuild the carb? is there a kit, or what is the best thing to do beside taking it to someone. My brother works on cars and will help me. i already bought a spare carb from ebay.
Old Nov 17, 2005 | 11:05 PM
Silver Ponys's Avatar
Silver Ponys
Does the engine use a lot of oil? A little smoke on startup could be valve guides. Dont know about a 6 but on an 8 you can get seals for the valve stems. If you are going to drive it a lot you may want to have hardened valve seats installed for unleaded gas.
My first car was a 67 6cly. My dad had our mech take the head off once and scrape the carbon off the pistons. It didnt foul the plugs anymore until i completly wore it out.
Old Nov 20, 2005 | 02:46 PM
my 67's Avatar
my 67
didn't burn alot of oil, but I only drove it 500-600 miles for the summer.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
