Front tires
Old Nov 14, 2005 | 03:11 PM
newownerof72's Avatar
newownerof72
Default Front tires
HI all,
As some of you know, I have a 72 that I am continuing to have problems with...the newest thing to set me back is my front tires- the hubby drove the car Saturday and found that the tires, both of them on the front, are worn down to the belt. Why is this happening? Most of the tire looks good, it is just this one inch wide worn spot almost all the way around.
Thanks guys,
Charity
Old Nov 14, 2005 | 03:26 PM
gta289's Avatar
gta289
Default RE: Front tires
the reason behind that problem is due to a bad alignment. when the tires wear to the belts on one side its due to to much positive chamber, a good alignment shop can fix the problem, however if the strut rods are bent, or the crossmember in the front is pushed back from hitting a curb, than youll have some expensive problems to address. First check the front strut rods, and make sure there tightened to the lower control arm, and check to make sure there not bent in any shape or form.
Old Nov 14, 2005 | 04:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
Simple solution. Take it to an alignment shop. If there are bent parts, they will tell you about it. If there are bent parts, have them replaced, then get it aligned.
Old Nov 14, 2005 | 11:23 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably the bushings on the lower control arms my 72 was like this
Old Nov 15, 2005 | 06:01 PM
67_FASTBACK's Avatar
67_FASTBACK
have your tires adjusted at the shop. its having excessive camber or caster.
Old Nov 15, 2005 | 08:29 PM
shamus66's Avatar
shamus66
don't feel bad... same problem is happening to me, i'm in the process of fixing it though.
-shamus
Gene K
Oct 21, 2015 11:37 PM
Oct 7, 2015 07:02 PM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
