exhaust pipe.
Old Nov 14, 2005 | 05:39 PM
tylerdru's Avatar
tylerdru
Default exhaust pipe.
Does anyone know of any good ways to seperate two connecting exhuast pipes? they are not welded and the clamps are off.
thanks!
Old Nov 14, 2005 | 07:26 PM
6mustang6's Avatar
6mustang6
Default RE: exhaust pipe.
I just ripped mine off after awhile. I kept bending it, til it broke. There hard to take off.
Old Nov 14, 2005 | 07:42 PM
BillyBobJoe's Avatar
BillyBobJoe
try a torch, keep the flame small enough to only heat the metal and loosen it. otherwise, just cut it off if you are replacing it.
Old Nov 14, 2005 | 09:06 PM
tylerdru's Avatar
tylerdru
well screw it! I am going big!
http://mustangsunlimited.com/itemdy0...atKey=EMUSTANG
Old Nov 15, 2005 | 08:44 AM
Soaring's Avatar
Soaring
I ♥ Acer
2 1/2 inch pipes, huh? What made you decide on that size?
Old Nov 15, 2005 | 04:47 PM
tylerdru's Avatar
tylerdru
no, i am gonna get the 2.25 inch setup. it is cheaper too. I wasnt paying attention to the little details i was just saying i was going to get a new system.
Old Nov 15, 2005 | 04:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then get the 2 1/4 with an X pipe or a Y pipe. Your concern should not be the sound of the exhaust system, but how it breathes. You know damn good and well that the X pipe is superior to the H pipe. You also know my feelings about mufflers. Loud does not equal performance.
Old Nov 16, 2005 | 04:05 AM
garywwelch's Avatar
garywwelch
In the article that SOring posted it mentioned the 2 1/2 or 3 inch pipe would produce more torque. What isthe best size pipe to go with the 2.25, 2.50 or 3.0?
Gary
Old Nov 16, 2005 | 09:28 AM
Soaring's Avatar
Soaring
I ♥ Acer
That depends on your power range. If it is in the 3-4 K range which is what 289's are, then the 2 1/4 pipe is best. It scavanges the exhaust well, but retains just enough back pressure. If you put larger pipes on it, you lose some of the scavenging effect, and will have virtually little back pressure. Now, if your power range is 5-7K, then the 2 1/2 to 3" pipes are best. On those engines, most of them use 3" pipes out of the headers to mufflers, then 2 1/2 out the tail. Bottom line is that bigger is not always better.
Dokilar
15
Oct 16, 2015 08:13 PM
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Sep 24, 2015 09:18 PM
